Greg Rozar AKA- CubDieselFan
Old 12-30-2018, 07:54 PM
sawdustdad's Avatar
Default 3D printing?
Anybody doing any 3D printing? I got an inexpensive printer for Christmas, and have been playing with it. Mostly making nosecones for model rockets (scale models of Mercury, Gemini and Apollo capsules).
Found this IH logo on line, printed one this morning. Any other CC stuff that might be worth printing? Steering column bushing, throttle, lift and hydro handles, Gear shift knob (which is now unavailable I think). The plastic can be most any color, I got black and white to start.
thoughts?
Old 12-30-2018, 08:20 PM
Can you make rear PTO accessories??
Nobody else can figure what to do with a rear PTO!!,,,
Now, not in jest,, how about printing a two piece fan that can bolt to a Hydrostatic driveshaft,,,
it would save a ton of work in replacing that fan,,,
Old 12-30-2018, 10:24 PM
sawdustdad's Avatar
Fan not a bad idea, but my printer is limited to a 4.7 inch (120mm) cube. But larger printers could probably do it.
Old 12-30-2018, 10:30 PM
A 4.7X4.7 size would be perfect for half a fan,,
make 2 that could bolt together around the shaft,,
make the blades thicker,, and more of them,,
Go for it!! they will sell,,,
Old 12-30-2018, 10:58 PM
sawdustdad's Avatar
Isn't the fan more like 6 inch dia?
Old 12-31-2018, 11:55 AM
It is a ,,,,,,,, fan,,,,,,,, make it any size you want,,,
smaller diameter, make the blade a little wider,,,
Old 12-31-2018, 01:43 PM
john hall's Avatar
I probably have an extra feed grinder you could belt up to that. Start raising chickens!
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 12-31-2018, 02:04 PM
We have chickens,,
EVERY place around here that sells corn,,,
charges the same price for whole kernel as cracked corn,,,
AND, as far as growing it,,
I can barely grow enough for me to eat,, let alone the chickens,,,
Old 12-31-2018, 09:44 PM
john hall's Avatar
We have chickens,,
So, you can come get the grinder now. It'll be October before I have any more corn. Just leave your truck, its cheaper in bulk.
2072 w/60" Haban
Old 01-01-2019, 10:20 AM
Smittyizer Smittyizer is offline
I’m sill making and selling a few of those emblems for the 82 series on eBay. Your picture looks like you’re dialed in pretty well.
I like the idea for the fan, but wouldn’t be too confident in it staying together at the speed those things rotate at. I’d be afraid especially of layer separation in the fan blades.
Have also used an elastomeric type material to print off the rubber cover for hydraulic lift handle when I added dual valve to my 782. Didn’t come out as clean as I would have liked on outside, but it’s functional. Used same stuff then to make some dust caps for the front outlets that I put on.
File Type: jpg D1956523-2795-4D13-883E-8CDFB53A1DD9.jpg (14.5 KB, 118 views)
Just a Red 782 ... so far
