Greg Rozar AKA- CubDieselFan
Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 01-28-2018, 07:24 AM
JacksCubcadet124 JacksCubcadet124 is offline
Default Cub 124 Hard to Start--my first post
Hi, Cub Cadeters:
I have a 124 that wouldn't start. I changed the plug (216), points, and condenser. After I attached the jumper pack it would try to start puff smoke and eventually run great!
How can I make my tractor start easier? Should I replace the coil and increase the gap in the plug?
All help is greatly appreciated.
Old 01-28-2018, 07:39 AM
First, welcome to OCC......
You state you added extra battery capacity (Jumpering) leads me to think that the original battery is not up to par. Charge up the battery and take to a reputable testing place and have it "load" tested. If weak, replace it.
Roland Bedell
Buy: Made in the USA
Old 01-28-2018, 07:53 AM
john hall's Avatar
Like Roland said, your battery sounds weak---address that first. If that doesn't solve it, post what you gapped the plug at and did you install the points per Kohlers static timing instructions. Yes its more work to install this way but you will be more than pleased with the results. If this doesn't solve it, then start chasing other possible trouble--bad wiring, coil, fuel issues. Be systematic with your troubleshooting and report your results back.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 01-28-2018, 08:16 AM
Default I learned something new
i just Googled Kohlers static timing instructions and will try it today.
Thanks a million!!
Old 01-28-2018, 08:33 AM
john hall's Avatar
Thanks a million!!
If you look in the technical section here on OCC, you will probably find the Kohler manual as well as IH manuals for that and many other machines as well.
By the way, try searching past posts for static timing. There have been some really good suggestions. Hardest part is seeing the mark on the flywheel--especially if its rusty. Common sense will tell you its going to be viewable about the time the points open, but it can still be hard to find--seems the mark isn't always dead in front of the hole, kind of off to one side.
2072 w/60" Haban
Old 01-28-2018, 08:58 AM
twoton twoton is offline
.....How can I make my tractor start easier?.....
Does this mean it cranks well but has a hard time firing off or doesn't crank well or... what?
..... Charge up the battery and take to a reputable testing place and have it "load" tested. If weak, replace it.
Once you have confirmed that you have a good battery that is fully charged, start working your way "down stream" with a meter through the wiring harness ( starting circuit if you're having a hard time getting it to crank well) and verify that you have the same battery voltage along the way. A sudden drop in voltage will indicate corrosion or faulty wiring, switches etc...
Wiring diagram is in the tech section under tractors.
Old 01-28-2018, 09:43 AM
Your timing can be spot on but if you have a "weak battery", you still have a problem.
Roland Bedell
Old 01-28-2018, 10:34 AM
Both - I attached jumpers and it cranks faster, so I know my battery is weak, but it takes a while before it actually runs.
I have a spark tester on the plug wire and confirm it is firing, just takes some work to get her going. Once running sounds excellent. Also, smokes a bit while cranking.
Based on the description, i think the timing is off. Please correct me if you think i am wrong. I am truly open to learning from you guys.
Since it's a 50 year old tractor and 95% original, it wouldn't surprise me if the wiring or switches are corroded
Old 01-28-2018, 10:48 AM
Replace it with the largest CCA rated Battery, that will fit in your Battery Box.
Roland Bedell
Old 01-28-2018, 11:00 AM
will do
