Greg Rozar AKA- CubDieselFan
Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Briggs & Stratton Engines
Old 10-03-2018, 06:36 AM
ihcc1 ihcc1 is offline
I wanted more info on the meaning of the numbers etched on the Mikuni carb because I was trying to figure out if the carb was original to the engine.
I believe I have stumbled on to a clue! The engine CODE : 98030611 means the engine was manufactured 03/06/1998. Correct?
The B&S repair manual says (on the carb index, page 75) the Mikuni carbs were used on this engine (303447) before 08/01/1995 and they used a Nikki carb for my engine starting 08/01/1995.
Either they used a left over Mikuni carb body (explains same #'s as on Nikki carbs) or someone replaced the carb (doesn't explain the Nikki #'s on the side).
If I knew what the #'s on the carb represented (date code) then I could confirm either way.
Old 10-03-2018, 06:39 AM
Side note,
I contacted B&S. They replied, B&S didn't use Mikuni carbs on there engines.
They were no help at all!
Old 10-03-2018, 08:19 AM
Since there is a bunch of unknowns, and you have hit a "dead end" in some avenues, there is only one way to get back to original. Bite the bullet and get the correct Carb for your tractor. Then you will know everything is correct. There is no point in throwing money at someone else's cobble job.
That is my suggest. It is your tractor, your time, your money, your decision.
Roland Bedell
Buy: Made in the USA
Old 10-03-2018, 06:09 PM
My 303447 has a spec code of 97111111. Let me go snap a few pics for ya.
Old 10-03-2018, 08:09 PM
IH, the over flow tube is only 3"-4" long (or 10" depending on who I'm talking to) and just points down.
Here are some pics of the carb. The numbers on the side are:
6100 22-121
808069 94(looks like a 4)B
Old 10-04-2018, 06:53 AM
Hey, thanks OAK!
That looks like mine. I have seen no evidence of any other "WORK" done on the machine so I'm guessing it was a left over carb shell that was used. Also only has 362 hours and I'm confident that is correct. No wear in usual places.
Old 10-04-2018, 02:29 PM
Based on the numbers you posted "303447, 1279-E1" this is what you are supposed to have on that engine.
https://www.jackssmallengines.com/ja...303447-1279-e1
https://www.jackssmallengines.com/ja...-e1/carburetor
