This idea has been brought up in the past, we won’t mention who but I’m glad it has finally come to fruition. I have several pics of some good ones but afraid that they will be sideways or upside down. It is truly amazing what some have done to these poor machines over their lives. Keep the pics coming!
Well, I don't think Sorner's original entry will be beat, but I'll play anyway. Here is the battery hold down on my 2284. It's on the rod that tightens the mule drive belt.
The hydro lever that came in my 1641.
Cannon |
Thanks for the offer Sam, I have a bunch of tubes in my POP (Pile of Parts). You know, I was so dumbfounded by the driveshaft setup that I didn't even notice the plumbing mod right away?! I haven't really gotten into the red 682 yet that I got from the same seller, but at quick glance it has no brakes.. at all. The disks are gone, there are no calipers or linkages. It has a pedal though, that is about it.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower IH Cub Original with deck #2 cart GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck |
Take your pick here
IIRC these were all on the same machine. Best part of this $75 Cub 128 was hiding under the belly pan which was crammed/wedged between the fender pan and the tower. I did not even notice 'til the next day after I got home! I have no idea as to what that tiny Kohler fits, sure as hell ain't this tractor The last picture, the pin had been pulled towards the front and the rear of the pin was not even in the rear bushing, just rubbing on the underside of the 'C' channel We need a "Custom by Cobblecraft" Hall of fame...er shame!! |
So here’s what happened. The PO has the driveshaft in backwards, and did not have the bolt in the center that holds the coupler to the input shaft of the charge pump.
Previous owner must have been a plumber.... not necessarily a good one, but copper tubing and compression ftgs...
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
