Greg Rozar AKA- CubDieselFan
Old 06-29-2018, 03:36 PM
idruthrbfishin idruthrbfishin is offline
I can tell you where he's gonna be if I can't get this thing runnin'!
Old 08-09-2018, 11:01 AM
UPDATE: Bought brand new carb ($70) off of Norm at iSavetractors.com had to switch a few minor things, (choke shaft, throttle shaft) both were super easy to swap. Installed carb, opened fuel valve, left bowl fill up and she started up and purrs like a kitten. Only adjustment I had to make was to adjust the idle screw. Mowed my entire lawn and it worked perfectly. Then I took it to my cabin and spent 3 straight hours mowing and she never even hiccuped. New carb is styled after the old style Carter carbs with all the adjustments, plus removable seat and main jet needle. Highly recommend checking out their site.
Old 08-09-2018, 01:22 PM
I'd sure be checking to make sure the main jet is open enough. It will run lean, and most people never know until it's too late and you score a piston. Read the manual and adjust it accordingly.
Old 08-09-2018, 01:48 PM
I do have a manual, I will check it out. I was actually worried about running lean. Someone once told me that a good indicator of lean/rich conditions is the color of the center porcelain on the plug. Black is rich, white or is lean, and a tan or chocolate color is just about perfect. Anyone else ever hear that?
Old 08-09-2018, 03:43 PM
That's correct. A spark plug color chart is in a lot of service manuals.... but you don't need to pull a plug to figure out the carb adjustment. Read the manual on how to adjust it, and err on the side of rich. Air cooled engines like it a tad rich.
