Greg Rozar AKA- CubDieselFan
Old 03-26-2018, 06:12 PM
mobermiller's Avatar
mobermiller mobermiller is offline
Default Kohler M18 valve seats
Hello all,
I'm working on a Kohler Magnum 18hp out of an 1810. I bought this cub as a flip, but soon found out I got shafted. The cub apparently had been left outside and the gas tank all the way to both cylinders were full of water. There was enough corrosion in the engine to pit the intake valve seat.
My question is this, does the intake valve side have a valve seat insert? The parts break down calls for 4 seats, but the jug sure doesn't look like its got one on the intake side. The exhaust side is pretty and shiny and I can tell it's an insert.
Is it possible to grind this seat with the proper angled stone using a drill press? Has anyone done this?
Looking at the photo, the intake valve is on the right.
Thanks so much for the help!
1961 4 digit serial #9643 Original Custom Restoration
1976 1650 dual stick
1989 2072 374 Haban Deck
2001 3240 60" Deck
2A Tiller
Old 03-26-2018, 06:18 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
A valve seat cutting tool may help. A kit such as this is handy...but pricey.
http://www.cylinderheadsupply.com/ne...yABEgLsA_D_BwE
An engine machine shop may be able to clean up that ugly seat.
Queen Of The Quietlines!
Old 03-26-2018, 07:13 PM
Take it to a machine shop and have the seats ground. Put it back together, sell it and be happy. DO NOT use a drill press as a valve grinder, or you will have to put a set in it.
Old 03-26-2018, 07:37 PM
After you have the seats ground, they should also grind the valves.
Then the valve clearance needs to be set by grinding the valve stems.
(after the cylinders are bolted to the block)
Also you need intake valve stem seals.
Guaranteed yours are hard and/or broken.
Old 03-26-2018, 08:12 PM
Here's some info on valve seals and head gaskets to save you some money.
http://www.onlycubcadets.net/forum/s...ad.php?t=50013
http://www.onlycubcadets.net/forum/s...ad.php?t=50014
Old 03-26-2018, 10:09 PM
Thanks so much for the information!
2001 3240 60" Deck
2A Tiller
