Greg Rozar AKA- CubDieselFan
Old 08-05-2018, 06:16 PM
RYoung913's Avatar
RYoung913 RYoung913 is offline
Default Installed rear axle braces
Well I took everyones advice and got the rear axle reinforcements for the 2072. No instructions came with them but its pretty straight forward so I just took the weight off the rear end and bolted everything up. Refilled fluid and now I have a leak at the axle tubes. I installed the thin washers on the outside of the braces, should they be between the brace and the tube? Or am i forgetting/missing something else?
If I'm taking it apart again I want to do it right this time because refilling is annoying and time consuming.
Old 08-05-2018, 08:56 PM
V30crewcab V30crewcab is offline
I think you need thread sealant on the bolts so it wont weep out.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 08-05-2018, 09:56 PM
DieselDoctor's Avatar
I just installed a set on a 1772, I put the washer under the head of the bolt and used little silicone sealant on the threads. No problems.
Old 08-05-2018, 10:04 PM
RYoung913's Avatar
Thanks guys I’ll pull them out and put some sealant on them, maybe I’ll work faster this time around lol
Old 08-06-2018, 06:33 AM
You can use a vacuum cleaner hooked up to the dipstick tube when you pull the bolts out. The suction will keep the oil from running out of the bolt holes. I use Permatex # 3 on the bolt threads. Clean the threads first with some brake clean.
Old 08-06-2018, 09:28 PM
RYoung913's Avatar
I like that idea! I’ll let you know how it goes. Thanks
Old 08-08-2018, 01:38 PM
sorner's Avatar
sorner sorner is offline
Just don't tell the mrs...
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower
IH Cub Original with deck
#2 cart
GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck
Old 08-08-2018, 05:35 PM
Yep, I use an old vacuum pump for HVAC work to suspend the oil in the rear when replacing a leaking bolt. I use Permatex #2 and torque to 30 ft/lbs. Just make sure the area is clean so you don't suck any junk into the hole.
Old 10-26-2021, 09:21 PM
aagitch's Avatar
aagitch aagitch is offline
Will these braces interfere with the SGT cat 0 hitch? Looks like part of the brace mounts where the lower lift arms mount.
Adrian
2072 (789513)
Old 10-26-2021, 10:02 PM
CubDieselFan's Avatar
I have Diesel Doctors 1772 and it has a 3 point. I will look at it closer and shoot some pictures.
