I use red locktite on the screws and that is all. Might want to take them out again someday. You can crimp them with a pair of needle nose vise grips if you want.
You might be able to get a felt washer at a hardware store. |
Be sure and file the threaded end off the tiny brass screws that hold the shaft to the plate.
Otherwise, you will break the heads off the screws off and then you will be screwed. |
My 2 cents on the Kohler or Hillman bushing - It will get you a couple of years use, then you are back where you started. With the bushing you have greatly reduced the bearing surface and it will not take long to wear the shaft. The last one I did with the Hillman got me a year and now I can wiggle the throttle shaft.
I am going to try a bushing that is the full length of the bore in the carb top. |
So, stick 2 of 'e in there.'
I think there is room. My 'O' ring fix w/1 brass bushing is still holding nicely. |
