Greg Rozar AKA- CubDieselFan
Old 08-21-2018, 12:02 PM
dbuck dbuck is offline
Smile
Hey Mr, J-Mech, if those engines have balance gears, should not they be chucked in the trash can?
Don B, USAF 1962-1968, Ft. Wayne, IN
Old 08-21-2018, 01:49 PM
I don't put them back in.
Old 08-22-2018, 10:28 AM
mickb72 mickb72 is offline
Because there is a crank bearing. Two of them.
There is no rod bearing.
Sorry to Apex, terminology do get mixed up once in a while. Crank bearing= never seen a bad one. Mike
Old 08-22-2018, 10:38 AM
Bad bearings happen. Just not often.
Terminology often gets mixed up by the inexperienced.
Old 08-22-2018, 12:22 PM
cooperino's Avatar
Why does everybody think there is a crank bearing? There is no bearing. Aluminum rod on steel crank. Unless you have one cut in the rod.BTDT Mike
You can buy rods for kohlers with actual journal bearings installed in them. I asked which bearing the OP was talking about because who knows what his engine has in it. Could have been rebuilt already.
Old 08-22-2018, 12:24 PM
cooperino's Avatar
This is actually a really good question for Jon,
Have you done one of these with bearing? If so did you notice a difference? I would think this would make higher RPM's a bit safer at least for bottom end.
Or even at 3600 I would think it was have more longevity,.
Old 08-22-2018, 12:58 PM
I rebuilt a k341 a few months ago that had a rod bearing in it when I took it apart, the bearing and crank looked so good I thought about reusing it but didn't want to take a chance on the rod breaking.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-22-2018, 01:25 PM
Only advantage to a rod bearing is not having to replace the rod on a rebuild. Even then.... who wants to run an old aluminum rod? The guys who came out with the rod bearing insert are pullers who rebuilt often. Unless you are going to run the engine well above 4,0000 (5-10k) no real advantage. But if you go that high, you are going to be using a different crank and rod (designed with an insert) anyway.
Old 08-22-2018, 01:41 PM
cooperino's Avatar
Gotcha... Thanks for the info
Old 08-23-2018, 08:08 AM
Did the rod say Alcoa on it? That is the best one made and was used in the 18hp. That's the one pullers might reuse in a 4-5K rpm governed class. Mike
