Greg Rozar AKA- CubDieselFan
Old 08-15-2018, 11:12 PM
Steve N Mi Steve N Mi is offline
Default Mower blades for Haban 190-374-100
I did find some blades they say are Hi-Lift, fine. I am hoping someone can tell me where they have purchased Gator blades for this deck.
Hi-Lift blades, https://www.ebay.com/itm/6-Hi-Lift-B...53.m1438.l2649
Old 08-15-2018, 11:16 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
These are the blades we are using.. I haven't seen much else out there for them.. let me know if you find an alternative. Thanks
Jay
Proud owner of the following:
Old 08-16-2018, 11:22 AM
delikocc delikocc is offline
I use Gator P/N 96-346 on my 60" Haban. They are the correct length, hole size and offset but a little too wide; 2 1/2" wide vs. 2" required. I machine the Gator blades equally on both sides in the spindle mount area to fit.
I went through the Gator catalog by the required dimensions and this was the best fit available.
Old 08-16-2018, 12:40 PM
taylorjm taylorjm is offline
Hey Steve. From Midland I see. Saginaw here. What kind of cub do you have with your 60" haban?
delikocc - So how are the gators? I also heard the only way to make them fit is to grind them down. My 60" haban doesn't mulch well at all. If I had to guess it wasn't designed to mulch. I do have a mulch plug but it would just clog up behind me if I used it. My neighbor has a JD and he can cut grass that's twice as long as mine and it mulches great. I have a couple thick spots that I either have to go over again, or use a lawn sweeper on.
Old 08-16-2018, 05:00 PM
1872
delikocc - Do the gator blades work well, i.e. better than the regular blades at reducing the discharge size? On my 50" deck w/gator blades I noticed that it wasn't necessary to sweep nearly as much as with regular blades.
Old 08-16-2018, 11:22 PM
And he prolly has a high vacuum deck, or one designed for mulching. Can't compare, unless it's the same deck on both tractors...
Old 08-17-2018, 08:26 AM
I love the Gators on the Haban; been using them about four years. Not the same as a mulching deck, but the size of the clippings is definitely reduced. I'd say at least half the size of the clippings with regular blades.
An SGT with power steering and a 60" Haban with gator blades is a joy to mow with.
Old 08-17-2018, 10:12 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
And blade tip speed.
Old 08-17-2018, 12:11 PM
john hall's Avatar
How about HP in heavy grass, those Gators slow you down much?
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 08-17-2018, 12:15 PM
Dirty Steve's Avatar
Are the Gator blades hardened?? I'm not sure I like the idea of "machining" mower blades?
