Greg Rozar AKA- CubDieselFan
Old 07-15-2019, 08:40 AM
Frank1541 Frank1541 is offline
Default Hydro leak
My 2364i (1541) started leaking hydro fluid a couple of weeks ago. I had a spare ready to go that included extreme braces. A day later and everything was back together. I am not sure how I did it but I loosened the main wiring harness connector at the base of the pedestal. The connector came apart when I was done cutting the grass. A couple of days later I could not get the PTO to work, no rear lights and the seat kill switch did not work. After an hour of diagnosing the issue I remembered the main connector. Put it back together and everything works as it should.
Has anyone ever seen a break in the aluminum rear end that did not include the usual broken bolt connections near the hydro? Just trying to figure out why I got the leak on a unit that I had rebuilt less then two years ago. Probably a bad seal.
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
Old 07-15-2019, 09:38 AM
Your post is confusing, where is it leaking?
Old 07-15-2019, 02:44 PM
Possible leak points.
1: Cork gasket
2: Axle seals
3: Axle tube bolts (6 on each side)
4:Rear cover
5:Silicone between the main case and the adapter housing
6: Expansion plug
7: Suction tube
Now for the Pump
1: Relief valves
2: Input shaft seal
3: Output shaft seal
4: Trunnion seals
5: Hydraulic fittings
6: Miscellaneous plugs
7: Charge pump O-Ring
Old 07-22-2019, 09:06 AM
Rex B Rex B is offline
That's a pretty comprehensive list! Thanks for that.
My 1864 is also leaking fluid. I need to investigate that.
