1863 Steering Issue
Over the winter while plowing the steering became difficult on my 1863. I was near the end of my driveway when I wasn't able to steer at all in one direction. I was able to limp it back to the garage and found the large bolt/nut combo in the steering box to be loose. I re-tightened it and it was fine until yesterday while mowing. Near the end, it became difficult to steer again. Found the same issue again. What is the appropriate long term fix for this issue?
Nathan Gardners, PA Cub Cadet Yanmar SC2400 |
If the nut is coming loose clean the threads with some brake clean and then use some loc-tite on it.
Thanks. I think I'll do some investigating by pulling it apart. Wasn't sure if there were any known components that needed replaced. Thought about some loc-tite but wasn't sure if it was that simple...
If you want the service manual for the Cyclops, you can join Cub Cadet Cyclops on Facebook. https://www.facebook.com/groups/666265203510023/
Don't know what it is about Cyclops but I've had several nuts come loose and one box even had the nut completely missing.
A stover nut should keep it from moving. No need for loctite.
Thread Tools | |
Display Modes | |
