Greg Rozar AKA- CubDieselFan
Old 08-23-2013, 09:05 AM
I have three methods of part revival that will work for nuts and bolts.
BIG;
SMALL;
SLOW;
Big and Small use Black Magic grit, Slow uses Washing Soda, and a GT battery with a charger.
Old 08-23-2013, 09:31 AM
dag1450 dag1450 is offline
Wow you r set up ! do these spin or viberate ? Does the black magic work well, is it like a sand ? Im just looking to knock some of the krud off after the vinager bath.
Old 08-23-2013, 10:16 AM
They both spin, the "Small" was an epoxy mixer, works great!!
Maybe you could make one out of an old Cub Cadet transaxle!!
Old 08-23-2013, 11:13 AM
Matt G has a good write up on his site about replating bolts.
Old 06-07-2019, 04:28 PM
eberner's Avatar
eberner eberner is offline
Default Citric acid bath
I clean the hardware with acetone then put it in a citric acid solution (1 Cup to a gallon of water).
For a container I picked up one of those cheap plastic storage totes at an after charismas clearance sale. let sit 24 hours take them out then a couple of seconds with a wire wheel. It wont fix any pits but it'll shine like new. I've done an entire Brinly plow, an 1890 Oliver plow, & all of the rusty parts on my 127 this way.
Citric acid is the stuff in Catsup & Coke that cleans rust. Any way you can buy in on amazon or eBay (its the same stuff that goes into your wife's bath bombs) I like to dissolve it in hot water (gallon or so) and add the rest of the water. it non GMO, gluten free and most importantly non toxic. it doesn't off-gas like electrolysis and doesn't require special handling or special disposal.
Old 06-07-2019, 06:51 PM
I see you are new, welcome to OCC
You have replied to a post over 6 years old.
Thank you for the info, but you might get more recognition if you started a new post.
Just a FYI, no offence.
Old 06-07-2019, 10:29 PM
Plain old white vinegar for rust.
Mineral spirits for oil/grease.
Ya gotta get the grease & crap off first before the vinegar will touch the rust.
Then a trip to the wire wheel on the bench grinder.
Vinegar turns the rust to mush and the wire wheel takes it off.
Then toss 'em into a can/jar with a little diesel/solvent/mineral spirits whatever to keep 'em clean tiil Ya need em. I use peanut butter or mayonaize jars. Shake 'em up once in a while.
Old 08-21-2019, 07:32 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Thanks Paul, yea the wire wheel is very tempting at only $10 for the bench grinder, but the thought of handling every nut bolt and washer is overwhelming. Im thinking sand would have to do a better job than the shells but I don't know.Dave
THat's not counting the money you'll have to spend to replace the half of them that are launched into low earth orbit never to be seen again until you move.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
