Greg Rozar AKA- CubDieselFan
Old 10-29-2021, 10:45 AM
EternalArianne EternalArianne is offline
Default Spring tune up
I just got my 2155 ready for winter storage (drain gas and let it run until it quits, brought battery indoors where it's warm) and I plan on doing a full tune up in the spring since who knows last time it was done.
I wanted to make sure I'm not missing anything - I was going to do an oil/filter change, fuel filter, air filter, spark plug, hydro oil/filter. I already lubricated the deck pulleys when I replaced the spindles, as well as every other lubrication point I could find. Is there anything else I should worry about?
Old 10-29-2021, 10:56 AM
As a suggestion, follow the Maintenance Guide as outlined in your Owners Manual.
Roland Bedell
Buy: Made in the USA
Old 10-29-2021, 11:25 AM
Yes, I have that. Since my hour meter isn't working and I have no idea when anything was done prior, I just wanted to cover my bases so I have a "fresh start" this spring.
Old 10-29-2021, 11:28 AM
Cover everything in the Owner's Manual, starting from scratch. Then replace your hour meter (or fix what ever the problem is) then you will know, along with the time frame.
Roland Bedell
