CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Old 10-22-2021, 03:43 PM
ltxtim ltxtim is offline
Default LTX1040 PTO belt falls off crank pulley on disengage
I have a LTX1040 I bought new in Spring of 2013
Around 146 on the clock.
My current problem is when I disengage the PTO lever (non-electric), the belt sometimes falls off the crank/engine pulley.
In my history of PTO belts:
1) Original: I broke while cutting lots of leafs, was several years old
2) Homedepot Aftermarket: I don't remember exactly what killed this one, but I think it had falling off problems and the crank pulley cut it. It was after market (I needed one right away after #1)
3) Homedepot Aftermarket: (bought at the same time as #2) lasted a long time and got nuked when I didn't put a belt keeper back on perfect after replacing an idler pulley that went bad. (It was the two metal brackets that bolted on with the idler pulley.)
4) OEM replacement from MTD, was falling off like #2 and #5, has a small slice, saved this belt as better than nothing for a spare.
5) OEM replacement from MTD (bought with #4), keeps falling off on PTO disengage.
3-5 are all in the 2021 season.
I've read that sometimes this happens when you need to re-level the deck?
Is there anyway to adjust the belt tightness when the PTO is NOT engaged?
I do compare belt lengths when I change them to make sure they are reasonably the same size.
Any other ideas?
Thanks!
Old 10-22-2021, 07:51 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
Do you have the belt guide around the pto Pulley? Part # 747-05171A
I tried adding a pic but it didn't work, if you Google the part number you'll see a pic.
JD x475
Old 10-26-2021, 07:06 PM
Yep, that is in place and in the correct direction.
I checked for "adjustment holes" incase I put it back in a different spot, only one spot.
I have found that if I release the PTO leaver really slowly it won't fall off. (Internet searching lead to this suggestion and it works for me.)
Thread Tools
Display Modes
