Greg Rozar AKA- CubDieselFan
Old 11-24-2021, 05:28 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Default Have I mentioned NC has a lot of leaves this time of year?
Have I mentioned NC has a lot of leaves this time of year? (nearing the end of unloading todays haul at Johns Drive Through Leaf Dump)
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 11-28-2021, 01:06 AM
69Cub124's Avatar
69Cub124 69Cub124 is offline
Re organize all of the parts so it is out of the way and i have more space to do things for other projects until i can get what i need to start doing some body work
Old 11-28-2021, 12:54 PM
jbrewer's Avatar
I got my new original running.
Can we see pictures? :-)
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 11-28-2021, 05:47 PM
Farmall450's Avatar
I fired up the 2182 and moved it over (still in limbo -- waiting on backordered line from CC) so that I could pull the 1811 in the shop next to it (needs fuel pump, probably more).
Just bought the 1811 last week, so figured I'd change the fuel pump and oil and then see what else comes up.
Old 11-29-2021, 10:18 AM
Red Dave Red Dave is offline
Not today, but Saturday I put the blade on the 125, and put the iron weights on it too. I still need to put the chains on, then it will be all ready for snow season.
I like to get it ready for winter around Thanksgiving. We often get our first plowable snow in mid December, although we have had one as early as late October, or as late as January. It pays to be ready so all I need to do is start it and go to work whenever it happens.
Old 12-04-2021, 11:03 AM
Farmall450's Avatar
Last night I figured I'd live up Friday night and work on the Cubs:
2181 -- installed axle braces (still have 1 piece to go today). What a battle -- left everything loose and still couldn't marry the two together. Finally got it, but am definitely a little scared it'll leak (when the pulled the rear end bolts fluid came out. Not sure if someone used too long of bolts or these are supposed to be like that). Used sealer, but we'll see how that works. Also replaced the leaking hydraulic pipe that finally came in from MTD. Turns out it still needs the pump input seal, too.
1811 -- pulled tin to get to the fuel pump. Someone had replaced the pump and the gasket was only half on. oops! Replaced home made hitch with one from feebay.
Old 12-06-2021, 09:57 AM
Cubcadet_107's Avatar
Fired up the 106 yesterday, pulled the 38" deck off for winter. Then tucked it inside the workshop out of the elements.
'70 107 with k301 engine swap
'71 106 with 38" deck
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 12-07-2021, 08:31 PM
Farmall450's Avatar
Sat -- finished the other side's brace. Blew out the one hole a size, and it went together flawlessly. Also pulled apart the pump bearing holder and replaced the seal. Hunting for obsolete CC o-ring now -- my collection didn't go quite big enough and it's very flat, so I don't really wish to reuse it. SU-9004100-0360.
For reference, the seal is just an SKF 6904 for CC/MTD 921-3032.
Old 12-09-2021, 11:02 PM
Farmall450's Avatar
Wasted time tonight. Put a new (admittedly Amazon) fuel pump on the cheap 1811, and it leaked even worse than the original one *fuel.
At least I got the gasket on both bolts (unlike the last guy).
Old 12-11-2021, 08:24 PM
A month or so ago I dismantled the driveshaft of my 107, to remove the drive hub. Welded the notches up. Finally had time today to get around to reinstalling it.
Then took her out for a little drive and posed for some pictures
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
