Greg Rozar AKA- CubDieselFan
Old 11-12-2018, 01:01 PM
mrloring mrloring is offline
Default Power Angle with a winch
I have seen ATV plows that used a winch for power angle. Has anybody done that on a Cub? I have a 100 with snow blade and it would be so much more productive if I didn't have to get off and change the angle on every pass.
Old 11-12-2018, 01:41 PM
cooperino's Avatar
I saw one that angled with mechanical rods and he had another lever to lift the lock pin
Old 11-14-2018, 08:10 PM
You can plan it out better so that you do not have to get off of your cub for every pass. Angle your blade so the snow rolls off the blade to the right and leave it in that position. Estimate the center of the area you are going to clear snow on and then plow about 30 inches to the right of your imaginary center line that you established. On your return pass, do the same thing, but on the other side of your imaginary center line. Then as you pass back the same direction as your original pass, move away from that imaginary center line so that you clear snow that is about 2/3 of the way over on your blade, each time rolling it to the right of your tractor. Then make a return pass, doing the same thing, as you return back to your original starting location. Each time, you are expanding out further until your area is cleared.
Old 11-15-2018, 08:59 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Sould not be too hard.
If you can find a small winch that has power in AND power out.
Mount winch vertical up near grill, attach cable to end of blade.
Wrap around winch drum a few times and attach end of cable to other end of blade.
Might need a heavy spring inline on cable end to keep tension on cable.
Your basically using the winch as a capstan winch.
Old 11-15-2018, 09:11 AM
hyperlightboards48 hyperlightboards48 is offline
Well thought out! I like this idea.
Tanner
Old 11-15-2018, 09:14 AM
Leadslingingdaddy's Avatar
I thought Sam did something along this line for a rear lift??
Old 11-15-2018, 09:48 AM
I would use a linier actuator instead of a winch.
Old 11-15-2018, 10:09 AM
cooperino's Avatar
Yup. What he said.. Even electric one should not cost much, mounts easily and should work great.
Old 11-15-2018, 12:47 PM
DoubleO7's Avatar
True but when not using the blade the winch would be handy else where.
An actuator, not so much.
Old 11-15-2018, 12:52 PM
cooperino's Avatar
I already looked at an actuator.. 40$ on ebay. Its a small enough amount to spend for the convenience I think even if just used for power angle
