Greg Rozar AKA- CubDieselFan
Old 10-15-2018, 12:22 PM
cooperino's Avatar
Originally Posted by oneplustwins View Post
I did not use a piece of glass, just the file going across the head in all directions. I did notice the head gasket appeared to be oil soaked though. No oil is shooting out the dipstick. The vent line was replaced when i did the oil breather. It does smoke when running. I seem to get more smoke when i throttle up, or down. I also get smoke when i engage the PTO for the blades.
Ok. I hate to say it but I doubt you got the heads or block "flat" with a file in hand. Typically you would glue down sand paper to a piece of glass or a flat surface stone to surface the heads. The block is a little harder to do but usually do not require flattening.
Old 10-15-2018, 03:33 PM
Gompers Gompers is offline
Yeah you gotta do this. Not an option. Hopefully you didn’t get the block uneven. You can maybe check by putting the head on a surface stone or glass plate and see if you can get a .004 feeler under it. If you can, it needs surfaced more.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 10-15-2018, 04:01 PM
oneplustwins oneplustwins is offline
ok, I follow you. I will tackle it that way, and see what happens. Thanks for you the information. I will let you know what happens.
Old 10-15-2018, 04:31 PM
https://youtu.be/L1jFtTzLh7o
Here’s a quick video to show you how it’s done. I know it’s a flat head in the video but the principal is the same.
Old 10-16-2018, 06:40 AM
ccpullin ccpullin is offline
Wonder if you have vertical heads on your horizontal engine? the oil drain back holes are in a different location causing oil build up and drawing it down the valve stems. If so, you can drill the heads.
Old 10-16-2018, 09:09 AM
Are the CH engines like that also?
I know the magnums are like that but didn't know if the CH engines are also.
But he said he had problems before he changed the heads.
Old 10-16-2018, 09:35 AM
TNTs CC TNTs CC is offline
Good thought.
3240 870hrs - 48" 289 deck, front hitch, 3 hyd circuits, 54" blade w/hyd angle, 45" 2-stage snow blower, Sims cab, 5 42# suitcase weights and 70# rear wheel weights
GT3204 207hrs - 48" 289 deck, 45" 2-stage snow blower, 54" blade and angle cylinder
3204 580hrs - 48" 289 deck - Parts Tractors - 3208 560hrs (rusty) 3 hyd circuits, 3pt hitch, 44" deck - 3165 rust free roller
1650DH 54" blade, Xtreme cat-0 3pt, 44" deck, filled 23x10.5-12 Tru-Powers
