#121
It could have been worse. At least you can fix this before it becomes a problem later and you have to dig up your floor to fix it.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart |
#122
Thanks guys.
I asked them earlier today about running a 3" up the 4" and using the 4" as a sleeve. He shot that down too and said the sleeve had to be 2 sizes larger then the pipe. I'm trying to figure the best way to cut the concrete where it is 7-8" thick. Most saws I can rent will only go around 5". I will probably need to do multiple passes if possible. What do you all think of this plan? Strike a line about 1" on the outside of the 4" pipe. Get a 12" long masonry bit and drill holes every 4-6" about 8" deep. Take the concrete saw and run it down the line. Start swinging away with a BFH.
#123
Why not just dig a new trench and abandon the one in the concrete?
#124
That's an option too Lew but I still need to cut into the footing 12-13" to get the proper slope. Mr. Inspector said as long as the top half of the existing line is free from the concrete he would pass it. Either way I need to rent a saw and cut away. If I can't get the existing exposed I'll abandon it and run another.
#125
Oak,
How much of that pipe is under concrete? It looks like its right at the edge of the footing. Have you tried just breaking it with a sledge hammer? The way it looks in the pic it looks like it would break pretty easily. Just cant see how long the run is.
#126
Coop, it's buried pretty good.
I picked this saw up today off of CL. Home Cheapo & Sunbelt want around $125-$150 to rent one for 24 hours with a blade. I can only work a few hours each day after work so renting isn't an option at this time. I'll use this until I'm done and sell it. IMG_5796 (002).jpg Here is what I got done in about 2.5 hours tonight. Now it's gonna get fun where the pipe is getting deep. Dang it! I held my fone wrong. IMG_5790 (004).jpg I will also need to cut the other pipe so that I can put a 6" PVC sleeve over it.
#127
Jeepers Todd, if it ain't the weather, it's the man. Guy just can't get a break. Lucky you ain't up in these parts, you'd be dealing with frost pretty soon.
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#128
Todd you made quick work of getting that concrete busted out. I'm guessing some of the words you used helped melt the concrete....
61 and 63 Originals 123 (2) 782D 106, 147, 122 102 parts It's only original ONCE!
#129
Todd, one question, why didn't you get an inspection before pouring the concrete?
#130
Sam, a friend dug the footings for my mono slab while I was at work and dug them too deep so I decided to fill them with concrete. (Basically a footer like if I was going to do a block wall) I called the county before I did that to see if I could just use some 57 stone and they said I would need to get an engineer to sign off on that if I did so I said screw it and filled them with concrete. I had to call for them to do an inspection before I poured the footer and it passed but I didn't have that 4' pipe in there yet. A day or 2 before we poured the footer I shot it with my transit and found I didn't have enough slope for the floor drains if I laid the pipe on top of them so I threw the 4" pipe in the footing....my D/A fault.
I should have known better than all that crap above but wasn't thinking. I hope to get it cut out this weekend and have both 4" lines sleeved with a 6". I will then call for another inspection.
Thread Tools | |
Display Modes | |
