Greg Rozar AKA- CubDieselFan
Old 09-19-2018, 12:08 AM
greasemonkoid greasemonkoid is offline
Default 1782 custom driveshaft options?
My 1782 with just under 500 hours now has a driveshaft rattle. I changed the balls out in the rear joint, but it did nothing. The darn thing is annoying to the point I hate to crank it. The hub to splined shaft is tight. If I push a stick in there to load the coupling it gets quiet.
So what is everyone else using for cv or universal joints since the factory parts are not available?
Old 09-19-2018, 05:20 AM
Did you ever grease it?
Old 09-19-2018, 08:20 AM
For the last 100 hours that I have been the owner, yes. Frequently. Before that, it's doubtful.
Old 09-19-2018, 01:05 PM
CubDieselFan's Avatar
There is not a kit available, but the parts are still available. Jeff in Pa makes the pump adapters.
Old 09-19-2018, 07:48 PM
Mister monkoid I know you said it was “tight” but did you verify that the 10mm bolt in the middle that holds the coupling to the spline shaft is there and tight? Just making sure you covered all the bases. The smallest rattle can be magnified as you know.
Old 09-19-2018, 11:10 PM
Most everyone buys a used Cyclops CV shaft, and machines it to work in the diesels. Jeff in PA makes all the necessary parts. (Parts By Jeff, up top.) Holler at him and he will hook you up.
Old 09-19-2018, 11:33 PM
Yes, the center bolt is tight.
Alright, thanks for the info gentlemen. I will check into parts by jeff and see what happens.
Old 10-05-2018, 08:46 PM
Today I pulled apart the rear driveshaft joint and realized the greater part of the noise is coming from the pump. After inspecting another old one I had on the shelf it appears the only thing that could rattle is the piston block on the splined shaft.
Applying a load via putting a slight pressure on the steering wheel and the rattle goes away. Right after cranking when the oil is thick it doesn't make a noise either.
It seems like the power pulses of the diesel engine are slamming the splined shaft and the piston block together. Is this a normal occurrence? Seems like it would hammer the splines off over time.
Old 10-06-2018, 09:14 AM
Sounds like the pump adapter is wore out. Maybe the input shaft on the pump. Very common on a diesel. I promise, it's not the piston block loose internally on the shaft.
Old 10-06-2018, 03:27 PM
I guess sound can travel strange places through steel.
That's good to know. Thankyou sir.
