Greg Rozar AKA- CubDieselFan
Old 11-01-2018, 09:20 PM
Mudrig150 Mudrig150 is offline
Actually got some progress in today, pulled the motor, got everything apart, now to pull the transmission for the hydraulic lift swap.
Old 11-02-2018, 11:47 AM
Hopefully going to pull the transmission this weekend, and then I can finally put the hydraulic lift in, too. I'll also get the motor cleaned and the breather cover installed.
Old 11-03-2018, 10:57 PM
Got the steering column out to clean out the old grease and regrease it. The old oil and grease was disgusting. It was way too thick and sticky. It steers a bit easier now.
Pulled the transmission, that was it's own affair. It took almost 2 hours. It fought the whole way out. The brakes were in the way, the little arms that hold the front to the frame got caught, so did the charge pump. Overall, it was pretty frustrating. We had 2 jacks, wrenches, Jack stands, wheel weights for ballast, and a vice grips.
Old 11-04-2018, 06:56 AM
Green stripe wide frame's Avatar
Green stripe wide frame Green stripe wide frame is offline
If you were to take the fender pan off it would have saved you 1hr 45min.
102 soon to be tiller machine
108 mower
73 plow machine
169 soon to be mower
122x2 now parts machines
Parts 129
149 parts
61 "O"
104 job to be determined
Old 11-04-2018, 07:01 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Reminds me of the joke about the Dr. who turned mechanic who rebuilt the entire Chevy 350 thru the tailpipe. He used to be a protologist.
Plow blade
#2 Cart
QA36 snowthower
Old 11-04-2018, 07:09 AM
cooperino's Avatar
Mud,
Regardless of pitfalls, hard times. probably some sore knuckles, Looks like you doing a great job so far! I bet your learning a lot and having fun as well. Just think of how great the feeling of pride will be once ya geterdone!
Old 11-04-2018, 08:38 AM
john hall's Avatar
In all seriousness, pulling the fenders may be a lot easier for putting it back together. If memory serves me correct, the aggravating part will be getting the screws out of the floor boards. Some machines they come right out, others not so much.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 11-04-2018, 09:40 AM
Bob95065 Bob95065 is offline
Kroil and an impact driver are your friends. Be sure to support the mounts underneath with jackstands or equivalent before pounding in the bolts with the impact driver. I used this method and mine came right out.
Old 11-04-2018, 08:12 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Yes for sure pull the fenders! No need to work under all that.. Like John and Bob said.. some patience, impact driver, penetrating oil and i'll add in some heat and the floorboard screws will come out.. When you go back with them use a little anti seize .. I like the idea of the jackstands.. the extra support would really benefit the impact driver!
Jay
Proud owner of the following:
Old 11-04-2018, 09:16 PM
Terry C's Avatar
Terry C Terry C is offline
You need to read the chassis service manual from the tech library here.
You need to pull the fender pan. It’s step one.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
