XT2 Enduro No Start/Click
2018 XT2 Enduro
Mod.# 13AZA1CN010 D.O.M: 04/2018 Serial # 1D278H40385 Two weeks ago, issue began: Push button start, no start/no click(solenoid).. Tap solenoid with hammer, push button start...Starts up..runs great/strong. Continued use issue.. Tap solenoid/ starter..starts up.. Thought solenoid would be a good place to start.. Replaced Solenoid (NEW) one day ago. Now...Nothing, shorted out terminals(ok) turns flywheel. Display reads Battery voltage and Hrs Used (normal).. Checked safety switch under seat..good, disconnected, display reads seat. Popped off ignition switch/reverse button mod for investigation of corrosion, water damage...None, looks brand new.. When I depress key to start, I can here and feel the ignition module?? click softly and power up when display turns on..THAT'S IT.. Checked wire harness from Starter mod to Solenoid.. all looks good...Scheduled for pick up to go to dealer for service and diag..but just wanted ideas in the mean time. Thank you for your time. Best, Andrew |
Service Dealer replaced Push Start/Stop display Module on Dash. All Good for now.
I would suggest checking your Ground Cable from the Battery to the Chassis Contact point. Make this cable is clean, bright and tight, on both ends. Where it makes contact with the frame, make sure that yo are contacting bare metal. Let us know what you find.
I have my 2020 XT2 GX 50 loaded on the trailer for the same issue. I checked all the safety switches and such. I installed a new battery and it just clicks. If you try it 50 times you may get lucky. I wish I had advice but I will post what the dealer says. I want the push button replaced with a standard key
Thread Tools | |
Display Modes | |
