Greg Rozar AKA- CubDieselFan
Old 07-28-2022, 09:37 PM
MitchJ MitchJ is offline
Default What’s the story on cast iron oil pans?
Did any of the stock K series come with a cast iron oil pan? Mine originally had an aluminum one. We’re the cast iron ones aftermarket?
Old 07-29-2022, 06:45 AM
The cast iron pans are a Kohler piece.
Only place I have seen aluminum pans have been on AQS engines as installed in the Quiet Line Cubs.
You will/may have locate one from an earlier K301-341 engine.
These engines, as used in many make GT's are not all the same as you will see when you do a search on the Bay.
Beware of hidden cracks in a replacement CI pan around bolt holes.
Clean well and inspect before installation.
Tap very lightly with a small hammer, it should "ring" and not go "thud"
Old 07-29-2022, 06:20 PM
If a CI pan is cracked, can it be brazed? I'm sure it would take a bunch of cleaning but was just wondering.
Old 07-29-2022, 08:04 PM
mortten mortten is offline
Depending on when it was made some replacement engines had aluminum pans. I have a replacement K301 dated 1974 with an aluminum pan.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 07-30-2022, 02:42 PM
Default Thanks
Thanks for the information, I was just wondering since I have engines with both aluminum and now the cast-iron version.
Thread Tools
Display Modes
