PO mod for sure.
You can see where they cut and added a piece to the lift rod to extend it out from the other lift arm. |
Thanks Rolland! Much better now!
PO mod for sure IMHO You can see where someone cut and added a piece to the lift rod to extend it out from the other lift arm. And extended the footrest mount waaaay outboard. Originals are all over the place. They made about 65,000 of them |
I seen this Double lift handle before. IRC, a guy named William DeTurck (from another forum) had the same feature on his CCO. I don't recall what it was used for. I'll try to do some digging and see what I can find out.
UPDATE......
IH offered the Double Implement Lift Handle, as an option, so that one lever controlled the Rear Implements, and the other controlled the Front Implements. It was a Dealer installed option and it was only offered on the Original model. It appears it was not popular, and IH dropped that option on all subsequent models.
Wow, I bet that is probably sought after if that is the case. I never knew or seen one before. Thanks OP & Roland.
First time I've seen that. Factory?
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
Scarbro you wouldn’t happen to live right on the highway between Tuscon and the old west town of Tombstone? Bout 6 years ago made that trip and saw one on the way to Tombstone. Wife was askin' why I was driving so slow on the way back. Hardly saw any lawnmowers much less an old cub.
Ancestor of Allen's Dually!
Never seen two handles on an original, even had extend the foot rest. Pretty impressive.
