One thing to note: When I added the 7 qts. of Hy-Tran to the transaxle, the process went very smoothly because I filled it with the relief valves removed. This allowed the unit to vent, and the fluid went it quickly and without that annoying burping, which is usually messy and wasteful. I have a small plastic funnel that fits in the filler tube snugly, so that helped too. Something to remember when you are servicing these. I have done 4 tractors previously, and this would have saved frustration and time.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
Ugly front wheels sanded, primed and then painted using Rustoleum Almond. Came out great. Then I repacked the wheel bearings. Surprisingly they were not worn out, but they were dry.
That almond is a good find. I need to do the same for the fronts on the 984 and 782.
I agree. It's dirt cheap as compared to the Cub Cadet branded paints, and easier to locate. Since my machines are always garaged and kept cleaned, not sure of the durability, but Rustoleum has typically been good.
Your 682 turned out nice.
In case you didn't know, Ace Hardware carries their Ace Rust Stop brand in Almond Gloss. It usually comes in the bigger 15oz cans for the same price as Rustoleum's 12oz. I've used it with great success. Good luck on finding a mule drive and deck! |
Thank you. It shouldn't be too hard to find a setup.
That is the same color I used, matches just about all the cub implements. Nice work.
Menards carries it, but was out, however they promised me a quart on Saturday Both of them had 1/2 pints, but way to spendy
Refinished the grille
