Greg Rozar AKA- CubDieselFan
  #22
Old 07-06-2022, 01:14 PM
mortten mortten is offline
Did a little refresh on the 44C I converted to an A for the 1250. Wire brushed the underside, etched it and coated with POR15. Pulled the rebuildable spindles apart and cleaned them up and put new seals in. The old ones were bad and installed wrong. Wire brushed under the belt cover, etched it, primed and sprayed some white Rustoleum I had. Doesn’t match but it’s a worker. Sprayed some Fluid Film between the deck and support plate to keep the elements at bay. Greased the tensioner and the wheels and she’ll be good to go for quite a while.
Doug
QA-36A
42" blade
