Greg Rozar AKA- CubDieselFan
Old 03-19-2023, 05:23 PM
jonf6 jonf6 is offline
Default 107 Relief valve leak
I have a Cub Cadet 107. I need to know how I can remove the tunnel cover? This is not a shot one. The steering wheel console sit on top, 4 bolts hold it on the frame, 2 on each side.
Old 03-20-2023, 07:46 AM
The 107 does NOT have a "tunnel cover".
Roland Bedell
Buy: Made in the USA
Old 03-20-2023, 08:28 AM
Default relief vales
how do you remove the leaking valves then ,?
Old 03-20-2023, 09:17 AM
Take the Rear End out of the tractor.
Roland Bedell
Old 03-20-2023, 09:49 AM
Yup you will have to split the tractor. It is actually not as tough as it
sounds. After disconnecting hydro linkages and brake. drive line etc. There is only
a few bolts holding the rear end in place.
I would leave the wheels on it, that way you can roll it out of the frame.
The instructions in the manual are actually pretty good for this.
Once out,you will probably find there is more leaking then just a valve.
Like the cork gasket for one.
None of it is terrible hard. Just takes patience and a a lot of cleaning
of course. Enjoy it, that's why we do this.
Ken
Old 03-20-2023, 10:23 AM
Ambush Ambush is offline
Its one of those jobs that can be done quicker than all the time you spend worrying and procrastinating about have long and difficult the task is.
Old 03-20-2023, 05:10 PM
I resemble this remark. Till I did it once and went wow what was I
worried about. That was several times ago.
Ken
Old 03-20-2023, 09:29 PM
Jakespoon's Avatar
Jakespoon Jakespoon is offline
That was me when I did my 1450 cork gasket and took the sundstrand pump apart to change the seals. Sweated and thought a lot and jumped in. Wasn’t to awful bad.
IHCC original-70-105-124-147-108-1450 running and usable
Projects- Original--72-102-123-100-147-1250
Old 03-28-2023, 10:33 PM
Default Cub 107
Can I just lower it enough to get a socket on it with out dropping the rear completely.?
Old 03-29-2023, 06:09 AM
Can I just lower it enough to get a socket on it with out dropping the rear completely?
You are 95% there, so I suppose that could work.
Roland Bedell
