2182 Tear down....How??
I'm tearing down my 2182 and trying to get the rear plate off. How does this deck height adjustment rod come out? I stared at it for awhile and didn't see any easy way for it to come out.
2182, 1050 spread frame puller |
Appears to be a threaded rod with attaching nut. Remove the nut and it should come off.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
The nut on the end is left handed thread. Remove it, unscrew the shaft from part #25. Then pull the retaining pin, #24, out of the shaft, this is under the gas tank.
2364i (1541) Kohler ECH23 Power Steering 54" Deck 451 Snow Blower 42" Plow |
Thank you. I didn't think about left hand threads.
So I was tearing down today and found some electrical woes. Pics attached. The black connector I believe is for the headlights. I checked the electrical schematic and it doesn't show there being a connector for the headlights. I can't find a plug to match either just the one in the pic.
The white 6 pin connector is badly damaged from heat. I found a 6 pin molex connector that I'm thinking of using. Its hard to find these connectors without a huge minimum order. So I found the pic attached on amazon. Its rated for 20 amps and I believe the wiring size in the white connector is 14 ga and the plug is rated for 14-20. What do you think? Will this molex connector work and what does this black plug connect to
Yes, the 6 pin Molex Connector will work fine.
As far as the Black Connector, best as I can see it has BLU and GRN wires going into it, thus it would be part of the Lighting Circuit.
You are correct about the wires but I don't see another plug for it to connect to. I think it should be coming from the switch though. I will look more thoroughly tomorrow. Maybe its back there covered up in crud.
That two pin connector is for the PTO.
