Mule Drive Question
Will a mule drive from a cub cadet original fit on a 102. Thank you very much.
Got pix?....
Thanks for the rely. No pics till I unbury my Original from my shed. Looking at a 102 which needs a mule drive so i'm hoping it will work. They are both NF so maybe.
If it has the 38" 2 blade timed deck on it, there is no mule drive. The deck mounts using the brackets on it.
I might be using the wrong terminology. what is the piece below the frame at the front with the two vertical pulleys to take the belt from the front pulley on the motor and transfer the direction to horizontal and back to the deck drive pulley. That is what i am hoping will mount onto the 102.
I do not have a deck with the original, just the bracket at the front. The 102 will have a 42" deck. Thank you.
It is my understanding, that the "mule drive" from the Original is different from any other Cub Cadet tractor. With that in mind, I suppose it is possible to retro-fit a Mule Drive from a newer series tractor onto the Original with adaptation and/or modification.
If you are looking for a "Plug & Play" procedure, that is not going to happen,
Thank you, I will have to look for one for the 102 series tractors.
There's gotta be about a million of those laying around in PA. Give Rich Patton a call.
