Greg Rozar AKA- CubDieselFan
Old 12-22-2022, 06:05 PM
Sergeant's Avatar
Sergeant Sergeant is offline
Originally Posted by Farmall450 View Post
This, like every weather event, is blown out of proportion.
I sometimes wouldn't Mind seeing The Blizzard of 67 or 79 again
0riginal, 60 RER, 70, 106, 1450, 2182, 3208, XT3GSX & SX54 Z Force
Old 01-21-2023, 03:50 AM
Cannon51's Avatar
Cannon51 Cannon51 is offline
Yesterday I couldn't get the starter to turn the 1641 engine (Vanguard) over. I used some Channel Locks to turn it past the compression stroke and it fired right up. This was not the first time so after I finished what I was doing I got it in the garage and adjusted the valves. They were way loose. I haven't tried it yet because I broke the pulse nipple off the plastic fuel pump getting the valve cover off. I'll get that changed today.
Cannon
Old 03-04-2023, 07:01 PM
Hairtrigger's Avatar
Hairtrigger Hairtrigger is offline
Got some Cubs out today to give them fresh air and sunshine….I took advantage and swept the floor and cleaned
File Type: jpg 1C227033-2878-4B13-822F-5908D94E791C.jpg (34.6 KB, 202 views)
Old 04-18-2023, 12:41 PM
IHCubCadet147's Avatar
Saturday I took out my 1440 with the bagger and did the first mowing of the year, and cleaned up the leaves left over from last year. I forgot to take new pictures, so here’s one from last year.
Sunday I got my 149 running for the first time since November and used it to aerate the hard.
File Type: jpg 8ADAEF32-FE51-422F-B32A-D7820D9728A9.jpg (37.7 KB, 157 views)
File Type: jpg A6B16D30-922B-4117-9B29-587F42971A6D.jpg (39.7 KB, 156 views)
File Type: jpg A0D83C2A-69E1-43FB-88D3-18378B89AF8B.jpg (37.9 KB, 157 views)
Old 04-18-2023, 06:12 PM
Benne Benne is offline
I built a nice exhaust for my father's kinda 1872
I put a 27hp kohler crate in it last year. Unfortunately there were so kinks. The factory exhaust from the crate exited under the hood produced a lot of unnecessary heat. So I built a header that a v twin deserves. It's not much if any loader than the factory muffer but...way nicer and better sounding it's 1.25 primary with a 1.75 outer packed with 2 stroke exhaust packing. With a full port H -pipe ?
She sounds nice ! No obnoxious ! Still gotta get the 12"cooling fan wired in along with the new lights buts almost ready to slay the yard. Can't wait till she has a 60" deck to here that v-twin bark ahh!
I'd add pictures but have no idea how to do that ! I'm also on a phone so ya idont know?*? site is not awsome for a non intellectual pipefitter ahh
Old 05-03-2023, 05:00 PM
Frank1541 Frank1541 is offline
Mulch duty.
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
Old 05-08-2023, 05:51 PM
Farmall450's Avatar
Tried out the Brinly moldboard plow on my 782. Ran really well, actually.
Old 05-09-2023, 02:26 PM
I tested out the reel mowers that came with my Farmall over the weekend. I just greased them, didn’t sharpen them or anything yet, but they worked great. I just hooked up 3, which is 60”. I have two more yet that would make it 72”. They worked great, but not really practical for our yard. Too many tight spaces and obstacles to mow around. It was fun though. I had to use use the 1810 to mow the areas I couldn’t get to. Usually it takes me about an hour and a half to mow the whole yard. With these I had about 90 percent done in about 40 minutes, the maybe 15 minutes to finish with the 1810.
Old 07-04-2023, 09:48 PM
Ambush Ambush is offline
Over the past several weeks the 149 has been working hard at turning just less than an acre of thick dandelions and daisies into a food plot. Three rounds with the tiller two weeks apart. Then a heavy float to level followed by a weighted mesh float. After that I seeded, a light float, then rolled it with a homemade cultipacker. I had picked up a cultivator a couple weeks ago and I was very impressed how well it levelled the bumps off.
Old 07-04-2023, 10:21 PM
What a great Cub project Ambush. Food plot for deer?
Ken
