Cub Cadet Original Rotary Mower Deck Problem
I see on one mounting block for the blades for my original's mower deck, it is loose and wobbly, I also noticed that the other mounting block, it is tight and isnt wobbly, I also noticed too that the other one has some kind of cap on the top while the woobly one doesnt. In fact theres a threaded hole in the middle of it filled with grease. Does anyone know what goes here? I've looked at blow up diagrams of the deck and still cant figure out what goes there. Any help would be much appreciated!
I have the original Parts Manual (TC-82) for the CCO, and it does not show how block it mounted to the shaft, other than a 1/4" x 1/4" X 1/2" Square Key.
I don't own an Original. Our members that own Originals, should chime in.
The spindle shaft is threaded into the blade block and a key is place in from the bearing side before the spindle is put in the housing. I’ve never had one apart, so I don’t know a lot about them. You MIGHT be able to just replace the key and reassembled it, but the only way to know is to take it apart and assess how much damage is done. The hole in the bottom of the shaft leads me to believe the shaft is installed upside down, does it have a grease fitting on top? Check PDF page 17 in this manual... https://s3.us-east-2.amazonaws.com/c...Timed+Deck.pdf
149 with kwik-way loader,1772,two 1782 super smokers, 982 SGT w 54" haban blade,60" haban deck, 50in deck cat 0 3 point, brinly cat 0: blade, plow(3), disc.123,hydro lift. 61"O" Brinly single row planter,brinly cultivator,#2 trailer,brinly 10 inch plow,3 42 inch blades,Model #1 Tiller with extenstions,haban sickle mo. 106w/ags and hydro lift. |
Thread Tools | |
Display Modes | |
