Greg Rozar AKA- CubDieselFan
Old 01-11-2021, 01:57 PM
Eckenrot's Avatar
Eckenrot Eckenrot is offline
Default 1772 Restoration Project
So it begins.....
My son (14) stripped out his second drive shaft coupler this weekend. Along with some other issues and not to mention a pandemic he decided it was a good time to restore his baby.
He is going to need some help along the way, so thanks in advance. You guys rock! Here is wishing him luck and enjoyment. A journey of a thousand miles starts with the first bolt.
Proud Papa Cub
Old 01-11-2021, 02:37 PM
ATA boy. Have patience, take your time, research the issues giving you pause, and fix the issue correctly, will take you a long way to a successful completion.
Roland Bedell
Buy: Made in the USA
Old 01-11-2021, 05:16 PM
Time spent working/learning with kids is time well spent, they always turn out better.
Old 02-11-2021, 07:35 PM
Eckenrot's Avatar
Hey guys,
I've been working on painting my 1772. I was trying to put new axle seals on and replace the axle housing that has a chip in it. I am having trouble getting them off. I've seen that some people can just pull the whole thing off but mine won't budge.
thx everyone for the help.
Ben
Old 02-11-2021, 09:13 PM
cub123's Avatar
cub123 cub123 is offline
You need to remove the rear cover and take the clips off the ends of the axles in the differential, then the axles and tubes will slide off.
Old 02-12-2021, 03:45 AM
Bryan S Bryan S is offline
X2
I call them E-Clips/C-Clips not sure if that's their technical name?
It's part #8 that you need to pull out, then the axles will slide right out.
This link will show you the break down of the axles. https://www.partstree.com/models/177...le-carrier-46/
The Cub Pack. 70, 100 (creeper), 104, 122 (2), 1250, 1810, 1863, 2182, LTX 1050, SLTX 1050, SLT 1550, SLT 1554, Snow Chuckers 450, 451, 826T, 1030E, 2 plow blades. always looking for "just one more"
Old 02-12-2021, 08:46 AM
I strongly suggest that you download the service manual and read it.
https://www.onlycubcadets.net/forum/...ad.php?t=25397
Old 02-13-2021, 11:19 AM
FrankF3's Avatar
FrankF3 FrankF3 is offline
While you are in there so far, you may want to go in and drill some drain holes like Sam had suggested in the past to make sure nothing gets trapped in the axle tubes in the future.
https://www.onlycubcadets.net/forum/...l+drain&page=2
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 02-19-2021, 09:50 PM
Eckenrot's Avatar
Good evening,
I've been trying to get this gear to move to be able to get the c clips off to remove axels it seems to be hitting something not sure what's going on and the service manual diagram hasn't been much help. Any suggestions are welcome.
Thanks,
Ben
Old 02-20-2021, 08:43 PM
Eckenrot's Avatar
Just an update I feel stupid but didn't realize I just had to put some elbow grease into it and got the gear to move. I also thought id update you guys I've been trying to get everything painted. I've got the frame and rims and a few small parts ready.
