Greg Rozar AKA- CubDieselFan
Old 10-23-2018, 07:43 PM
Originally Posted by jaynjeep View Post
George I have an extra set of the short spindles.. they came with the 1862 axle and had some wear.. I looked on flea bay till I found a nice short set without the wear.. I will see what I can do about pic of the short ones but I don't have a set of long ones to photo
There is a noticeable difference when you see them though... It was easy to tell by a pic when I was hunting them
Thanks, a pix of the short ones prolly would do the job for all who are interested.
Old 10-30-2018, 07:44 AM
So here is a pix of the short, vs the long spindles of a super steer axle side by side.
The difference measured at the hood, on a 1650 with a super steer axle installed is 2-3/8"
Also, the long spindles have a tighter turning radius then the shorter ones.
Old 10-30-2018, 06:40 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Thanks for the pictures George! I haven't seemed to remember to dig my short ones out for a photo at the right time!
I used the shorter ones on this 782 build because I don't really like the nose in the air stance... reminds me of an old bulldog!
Jay
Proud owner of the following:
Old 10-30-2018, 09:25 PM
I just put the short ones on the 1650, still have the long ones on the 782.
Like you, I don't like the stance but it allows a really short turning radius and the ability to raise the deck up higher for mowing corn stubble & weeds.
What I don't like about the supersteer is, the scuffing of the grass on tight turns around trees/obstacles, but that is the ackermann effect.
Old 10-31-2018, 09:02 AM
Bamafan's Avatar
Bamafan Bamafan is offline
As I am now gathering parts for this upgrade on my 1450, I found this on E-bay. Is this the steering column I need or should I look for one without the tilt ? And is this a decent price?
https://www.ebay.com/itm/Cub-Cadet-T....c100011.m1850
Larry
Old 10-31-2018, 09:39 AM
Well that is not power steering, and I don't think it will bolt up to your manual
bracket.
Price:
I paid that for a Deere power steering unit for my 1650 and just a bit more for the power Deere unit on my 782 (both the same units)
I'm sure someone will be along to give better advice than me
Old 10-31-2018, 09:47 AM
Knuckles not spindles.
Old 10-31-2018, 11:16 AM
Just a heads up guys, the late 1862's have the tall spindles. So you need to check serial numbers. The axle I have for sale has tall spindles.
Old 10-31-2018, 04:24 PM
I would think the terms are interchangeable in this case.
https://en.wikipedia.org/wiki/Steering_knuckle.
But I would not argue terms.
Old 11-02-2018, 08:04 PM
Bamafan's Avatar
Guys! I am most appreciative of the comments that have been expressed here. But I want to do this upgrade to my 1450. So far I have been schooled on length of spindles/knuckles, what the definition to spindles/knuckles according to Wikipedia, and what i will have to do with deck should I use the short or the long spindles/knuckles.
Olds stated I needed an axle from a 1440, (of which I have found,) the 3 turn box I'm still in search of because I'm not sure of what I need. I posted an e-bay item that was a steering column from a 1440 but with tilt and I assume a 3 turn box. All I need is for someone to advise me of what I need for the steering column or if have to modify the original steering column, I can work the installation out if I have the right parts. Again thanks for all the comments and advice.
Larry
