Greg Rozar AKA- CubDieselFan
Old 12-30-2021, 12:32 PM
Gary C Gary C is offline
Default 1782 is a beast
Got the 54" Hydraulic plow installed, got the wheel weights installed and installed the new set of chains, tractor wouldn't stat. Put the charger on it, still no go. Plowed with the 1440. Started checking connections at the battery, low and behold, 1/4" bolts going through the 5/16" connections were loose. Cleaned all with a wire brush, installed 5/16" bolts with lock washers, started just fine . This past small snowfall I got to try it out. Love the Hydraulic lift and blade swivel, also the power steering. The tractor is a beast, nice power with even 1/4 throttle. Not use to the blade lift control just yet, my loader tractor was pullback to lift and forward drop. This forward to lift screws me up. If my brain can't be trained, I'll just have to switch the Hydraulic lines.
Old 12-30-2021, 12:48 PM
Farmall450's Avatar
Did someone switch it? I thought they were normally pull towards you/down to lift
Old 12-31-2021, 09:14 AM
Oak Oak is online now
I believe they are the same on the 3k machines. The center pin that controls the oil flow got turned 180* so now up is down and down is up......ask me how I know this. Pull the handle off and turn it 180* and you should be good to go.
Old 12-31-2021, 02:32 PM
Thanks! I'll take a look at that.
Old 12-31-2021, 10:10 PM
Farmall450's Avatar
This is a random question, but does anyone know why the 782 wasn't originally the 1782, and the 982 and 1982?
Odd to me that IH left the normal designations, then CCC went right back (171X, 181X, 191X) ... 1X82.
Old 01-01-2022, 01:25 PM
I think the ccc 782 I had was 17hp, this 1872 is an 18hp Super, a little longer frame, bigger wheels too.
Old 01-01-2022, 01:40 PM
According to the arrow on the dash, pulling the lever down, drops the deck and raising it up raises the deck. Same is true with the snow/dozer blade. So it is working correctly, my past experience with the loader tractor, and fork lifts. Pulling the lever , raises the bucket or the forks, and pushing it drops the bucket or the forks. I just have to retrain my brain for this operation. I don't have a loader tractor anymore, and I haven't driven a fork lift in 10yrs, so maybe this "old dog can learn a new trick" Happy New Year!
Old 01-01-2022, 04:52 PM
Farmall450's Avatar
Yes, a 782 is a 17HP (KT17 generally).
It's funny they dropped the "1" off then used the number later for a different tractor.
