Greg Rozar AKA- CubDieselFan
Old 12-24-2021, 07:42 AM
tweivoda tweivoda is offline
Default 1862 Wheel Weights
I picked up a set of the plastic covered cast iron wheel weights that came off a 1450 Cub Cadet with the plan to intall them on my 1862. Any techniques you folks use to install these. I think they are about 75# each and I can't "muscle" them into place and get the bolts through the weight. Any help would be much appreciate.
Old 12-24-2021, 08:25 AM
The 1450 did NOT come with plastic coated 75# wheel weights. They may have come from later generations of Cub Cadet Tractors. The weights you have will most likely mount with no issue.
As far as lifting them into place, can't help you there other than getting some extra manpower.
Roland Bedell
Buy: Made in the USA
Old 12-24-2021, 08:27 AM
If it is possible, one could stack a few short 2x4's or appropriate material along side of the tire and just pick up the weight and set it on them, allowing easy fastening to the wheel.
Usually, but not always, plastic covered weights are cement, not cast iron.
but I don't, nor have I seen everything.
#75 is not that heavy, but trying to hold up the weight and carefully align the holes, without damaging the valve core, is a bit of a chore without help.
Much easier to turn the tractor on it's side and let gravity work for you. Ha,LOL!
Edit: Roland types faster than I.
Old 12-24-2021, 08:35 AM
I don't have any wheel weights but have thought a little about your dilemma.
I figured I use one of the many little rolling carts I have. ( Shop just can't have
enough rolling carts).. Build it up to the right height and roll the wheel weights
into place. I would have to use the chain hoist to get the weights onto the
cart as well. Wonder as well if a person could pre mount them and roll the
wheels into place. Some here with real life experience will hopefully chime
in.
Ken
Old 12-24-2021, 08:54 AM
I use my engine hoist when mounting my wheel weights on my Kubota BX. They weigh 110LBS. I have a rod welded inside a pipe and a strap that hooks on the hoist. I lift the weight and slide the rod into the top bolt hole then I put a couple bolts in before removing the lifting equipment.
Old 12-24-2021, 11:12 AM
Farmall450's Avatar
What he said. You could try bolting the carriage bolt or all thread to the rim first, then sliding it on.
Old 12-24-2021, 11:29 AM
I got them of Craigslist and the previous owner said he had them on his 1450.
Perhaps the weights are concrete rather than cast iron. They have a few scars so maybe the previous owner had a difficult time getting them on as well.
I think the threaded rod, instead of the carriage bolts, might be helpful. I also think the idea of using a support rod that has been shown here can help.
I will give it another try. Thanks for suggestions.
Old 12-24-2021, 09:48 PM
Gary C Gary C is offline
I just put the 50# plastic coated concrete ones on my 1872 for the first time. I have a motorcycle Jack that worked ok for me, I cut a couple of pieces of angle iron and "c" clamped them to the Jack, the weights set on pretty well, put two carriage bolts through, wheeled the Jack towards the tractor,reached in and guided the bolts in to alignment with the channels in the weights. Pushed the weights into place and started the nuts. Next time I'll make or buy some collars to hold the carriage bolts in place, it's a struggle. Good luck! Tomoorw, I'll post a pic of the rig I used. Merry Christmas!
Old 12-25-2021, 02:57 PM
Default Installing wheel weights on 1872
Old 12-26-2021, 07:15 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Exclamation
The best way is to have the use of a helper. If one is not available, then the aforementioned methods will work.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
