Greg Rozar AKA- CubDieselFan
Old 12-15-2021, 10:40 AM
Mark Monger Mark Monger is offline
Default 1812 Driveshaft
I have read where the easiest way to reinstall the driveshaft on a 18xx is to loosen the engine and slide it forward. My question is, no farther than it has to be slid forward, does anything need to be disconnected? What do i need to watch for?
Old 12-15-2021, 01:52 PM
CubDieselFan's Avatar
How did you remove it? In pieces, I assume?
Old 12-15-2021, 02:05 PM
The Spirol pin on the coupler at the engine end sheared which let the shaft slide forward enough to let it come out of the pump end. After putting the pin back in the coupler on the engine end, the shaft won't slide forward now, so it wont go back the same way it came out.
Old 12-16-2021, 07:33 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
Remove the belt from the PTO, remove 6 bolts holding the engine pan in place, remove the driveshaft couplings, then slowly slide engine forward a couple of inches. Replace the driveshaft, and reverse the removal process.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 12-16-2021, 08:11 AM
On my 784, after taking the bolts out of the Flex Disc Couplers, I simply take the spirol pin out of the rear drive shaft coupler, slide the coupler down the shaft, and up comes the drive shaft.
Roland Bedell
Buy: Made in the USA
Old 12-16-2021, 12:59 PM
Thanks! I just wanted to make sure that I wasn't going to have to unhook any electrical connections or fuel lines to slide it an inch.
Old 12-16-2021, 01:09 PM
Thanks! My driveshaft has the disconnect clutch on it and the rear coupler wont slide far enough forward to allow me to do that. I was hoping it would as that seemed to be much simpler. Plan B is to slide the engine forward.
Old 12-16-2021, 01:15 PM
Sorry, you made NO mention of the optional disconnect clutch in your original post. Disregard my comments.
Roland Bedell
Thread Tools
Display Modes
