Greg Rozar AKA- CubDieselFan
Old 05-21-2021, 08:21 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Default 782/1811 front bumpers
I just finished adding bumpers to both of my Cubs that serve mower duty. The bumper on the 1811 is an original Cyclops part number 190-398-100 bumper. The one on my 782 is a 2000 series bumper part number 190-298-100 modified with brackets made by me to duplicate the much more expensive and harder to find bumper.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 05-21-2021, 08:27 AM
1711Cub's Avatar
Thumbs up
More pics..
Old 05-21-2021, 08:34 AM
1711Cub's Avatar
Last photo - the original.
Old 05-21-2021, 09:04 AM
SGragg SGragg is offline
Good job!
It appears from the photos that the (2) round tubes that run from the bumper to the brackets are welded onto the brackets, but the first pic of the brackets look like they're attached with a bolt/nut to a flange.
Is the bumper welded to the brackets or bolted?
Old 05-21-2021, 09:12 AM
1711Cub's Avatar
Originally Posted by SGragg View Post
Good job!
The bumper is welded to the tubes, and to the brackets. The only bolts involved are the bumper brackets to tractor frame, which are 1/2"-13 x 1.5" long with a lock washer-one per side.
Old 05-21-2021, 09:18 AM
1711Cub's Avatar
Old 05-21-2021, 09:23 AM
1711Cub's Avatar
Lightbulb
What I started out with. I loped off the two frame brackets, and ground old welds on the bumper smooth..
Old 12-23-2021, 01:34 PM
Farmall450's Avatar
I might look to do similar for my 1711 and 1282 (neither of which I expect to have front attachments on again). I made an offer on this bumper attached to a tractor on marketplace but didn't hear back from the guy.
For my 2182 (biggest concern, plastics) I scored a NOS in box MTD 190-672-190 or OEM-190-672 SR for $50, which while having different brackets, is spaced right to bolt on. Might have to trim some bracket back for other functionality.
Old 12-23-2021, 02:36 PM
1711Cub's Avatar
Thumbs up
Thanks for posting the part number of the newer bumper. Looks like a great alternative.
Old 12-23-2021, 03:22 PM
Farmall450's Avatar
Like you, I appreciate this kept the original look with 2 bars/pipes instead of a single one.
