Greg Rozar AKA- CubDieselFan
Old 03-17-2019, 12:55 PM
Sooner's Avatar
Sooner Sooner is offline
Default 1641 Fuel Tank Varnish
I’m looking for ideas to clean the varnish out of the fuel tank. I can reach most areas with a 40 degree pressure nozzle, but can’t reach the right saddle area.
Will turpentine, or paint thinner be too aggressive? I’ve entertained the idea of my handheld steam cleaner also. Thanks
Sooner Born and Sooner Bred, living in the Show Me State
Old 03-17-2019, 01:32 PM
dale c. dale c. is offline
I'd just clean it the best you can with the pressure washer then put a gallon or so of gas in it and shake /roll it around . make sure you have a good filter in the fuel line so if it cuts anything loose the filter will catch it.
Old 03-17-2019, 01:39 PM
Sooner's Avatar
I’m replacing all the fuel lines and fuel filter. The old gas had sat for several years. The rubber bungs, fuel cap and gasket for the low fuel sensor were semi liquified
Old 03-17-2019, 05:51 PM
Put some small gravel in the tank and shake it until your ears rattle. Then, rinse well with water.
Old 03-17-2019, 08:51 PM
I would try some Super Clean that you can get at Wally World.
Old 03-17-2019, 09:33 PM
Sooner's Avatar
I’ll check my local stores tomorrow. The right saddle tank area is so difficult to access for removal of this stubborn varnish. I’ll use It on the shut off valves also. I have another concern, as gummed up as the fuel lines were, what's the possibility the fuel pump is gummed up also?
I've had good luck with lacquer thinner and aircraft paint stripper,
but I never used it on a plastic tank and the pix looks like one???
Old 03-17-2019, 09:41 PM
Sooner's Avatar
Yes, it’s plastic. The picture is of the left side, the right [inaccessible] has the same varnish .
Old 03-18-2019, 06:08 AM
JRClift JRClift is offline
Dawn dish soap. Super clean , ...etc... may make plastic brittle.
Cub Cadet Model 100,( owned this one for over 25 years.:biggrin2.gif:, 2 Model 1250's, A/C B112, and 1939 A/C Model B.( My serious snow removal machine.)
Old 03-18-2019, 06:21 AM
Ditto, same here.
Roland Bedell
Buy: Made in the USA
