Cub cadet 100 and Overseas Carb
So i purchased a Cub cadet 100 ( Barn find ) Super awesome tractor.
I removed the carburetor and found that it needed a new float and overhaul. I opted to just get a new $38.99 Carburetor. What a mistake. I bolted it on and it ran like CRAP it would run okay than cut out. Or it would only run on choke. I played with the adjustments. Same thing! So i was going to take parts from the new carburetor and use them on my old Kohler carburetor that was originally on the machine. What do i find.. a float out of adjustment not allowing enough fuel for the engine to run. I adjusted the float so it was level and it ran perfect afterwards. I have always been suspicious of these cheap overseas carburetors. No quality control and they use inferior metals that do not last. If you leave fuel in them they begin to flake and the metal breaks down. |
The old carbs do the same thing. Nothing new. Has nothing to do with "inferior metal". So the float was out of adjustment. Big deal. It came on a boat over the ocean. I'm sure it got beat around along the way. Guys have been buying quite a few of these things and having good luck with them. You are the first to complain. Don Vogt took one apart and compared it to the OEM carbs. He said there wasn't much of a difference, if any at all. I figured you were going to say that you didn't clean out the fuel system and it plugged up. Hope you flushed the tank and put new fuel line on it. (If it has rubber line.)
I always just rebuild the old carbs. They're easy to rebuild. |
I just put a chinesium carb on my latest O and I’m not impressed either but it was cheap so it’s my fault. Plastic float not adjusted either, no big deal but after removing the bowl the o ring and bowl gasket swelled so bad I couldn’t reuse them. Then the throttle linkage hole for the rod that goes to the governor arm wasn’t big enough so I had to redrill to accept link. Also carb holes that mount the oil bath are tapped to metric and not standard machine thread (thinking #8) so I’ll have to retap or buy new screws.
Again none of this a big deal for me but like Jon I will always rebuild a Kohler, walbro, whatever carb first. Chinesium carb came with purchase of this O as the original carb was lost. Should have just bought used carb and rebuilt oh well I’ve seen others on here that are a fan of them but sharing what I’ve seen .
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
I had purchased a $25 ish chinese carb and it works perfectly. It had high reviews and had all of the adjustible jets and float. Starts with little or no choke.
Clay 149, 125, 100 w/ rear pto, fenders, and hydraulic lift. 5 snow plows, 1snow thrower, #2 ih cart |
YIKES!! I just bought a $14.33 China Cawbewator for my newly purchased 1450 (haven't picked up yet) and that price included shipping. I have high hopes and expectations for all of the money I have wrapped up in that carb!!! We'll see...…..but after reading these reviews, I am concerned about my investment.
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. |
