Greg Rozar AKA- CubDieselFan
Old 05-25-2019, 09:41 AM
Kennwa Kennwa is offline
Default Bolts
Hello.
Has anyone had all four engine bolts fall out on them. It happened to me on my LTX-1042. The bolts that hold the engine (Kohler) to the frame. My tractor is about five years old. I found the part number for the bolts so I will pick some up and install lock washers and Loctite on them. Seems unacceptable that this would happen.
Old 05-25-2019, 10:09 AM
Originally Posted by Kennwa View Post
Hello. Has anyone had all four engine bolts fall out on them. It happened to me on my ltx 1042. The bolts that hold the engine (kohler) to the frame. My tractor is about five years old. I found the part number for the bolts so I will pick some up and install lock washers and loctite on them. Seems unacceptable that this would happen.
Don't know about the new ones, but I picked up a running 1650 @ an auction
one time, and all 4 of the engine mounting bolts were MIA.
vibration is a weird thing.
Check the threads in the block if it is that type of mounting.
Old 05-25-2019, 10:29 AM
cooperino's Avatar
Hello.
Your engine was obviously telling you it was time to take it out and give it a good cleaning and a service!
Old 05-25-2019, 07:10 PM
In the newer stuff they normally have bigger self tappers that appear to gunned into non threaded holes during assembly which are an aluminum base. There’s a good chance these holes/threads are damaged. Inspect closely before repair
Old 05-13-2021, 05:52 PM
Larry954 Larry954 is offline
I just noticed one is missing on my LTX1040 (Kohler Engine). I tried 3/8 & 5/16 bolts and thread chasers. Are these metric M8 or M10? When I find a fastener, just use a torque spec for into Aluminum? I'll use a lock washer too. Kohler & Cub service manuals have zip on engine mounting bolts. For now, I guess I'll go remove one of the others and see if I can at least figure out the thread type.
Old 05-13-2021, 08:36 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
I've seen 1 or 2 missing and 2 lose.
Usually with 1 or 2 missing the thing vibrates so bad it's unusable.
With 3 gone and 1 lose in surprised the thing would even move.
I've always just run 3/8-16 bolts in any time i find one missing with Briggs and kohlers.
Kawasaki generally uses a 8mm bolts.
JD x475
Old 05-14-2021, 07:10 AM
The Parts Manual specifies 3/8-16 x 1"
Roland Bedell
Buy: Made in the USA
Old 05-17-2021, 07:33 AM
I went to my local Fastenal and bought a package of 2 thread cutting bolts in 3/8 x 1. Would have got 1 1/4" too but they were out. For some reason, before I tried those I gave a standard 3/8-16 another try and it bit and went in. Mowed my almost an acre and it is holding so far. Only reason I can think of leading to it going in this time is that the clearance hole in the frame is rather small and somehow all was lined up well enough. Not sure how I decided 3/8-16 was it. I was able to slide a longer bolt all the way in, but not sure if it was 1/4-20 or 5/16-16. Oh well, solved for now.
Old 05-17-2021, 07:52 AM
Esteban Esteban is offline
I have never seen all bolts come out. Could you not tell something was wrong when operating it ? I would think it would rattle the fillings out of your teeth.
