CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Old 05-18-2019, 07:13 PM
Andrew1045 Andrew1045 is offline
Thank you Dart...I will look into that and compare......thank you for reading and contributing..
Old 05-18-2019, 07:38 PM
ironman's Avatar
ironman ironman is offline
You're welcome but I'm running out of ideas. Here's a couple more shots in the dark....
The connector that goes to the fuel solenoid on the carburetor....
make sure it is a good connection and that you are getting 12 volts on it when the key is in the run and start positions. (zero volts when key is off). See top of page 25 in the manual. Also, if your tractor is equipped with the oil sentry, make sure the wire to it is attached.
Old 05-19-2019, 06:42 PM
Thanks Ironman, will do Sir..
Old 05-20-2019, 07:01 AM
Leadslingingdaddy's Avatar
Shoots some Carb cleaner into the throat of the carb and see if it at least's pops off...
Thread Tools
Display Modes
