Greg Rozar AKA- CubDieselFan
Old 03-24-2019, 12:03 PM
rudedawg's Avatar
rudedawg rudedawg is offline
Default Alternate muffler
I'm asking this on a couple of forums and hope to get help here also. I wanted to replace the muffler (# 951-3001P) on my Cub series 2000 2166 w/16 h.p. single cylinder Kohler engine but a new one is well over $200.00. I'm asking if anyone here has successfully used any other style/type/brand muffler on their shaft drive series 2000 Cub tractor. Thanks in advance.
Old 03-24-2019, 12:38 PM
I think the issue will be interference with the hood / sheet metal. Without the hood and sheet metal it should be easy the come up with something.
Old 03-24-2019, 03:28 PM
rudedawg's Avatar
Thanks Sam Mac.
Old 03-24-2019, 06:56 PM
ironman's Avatar
ironman ironman is offline
Here ya go Boss, 30 bucks plus s & h....
https://www.ebay.com/itm/Cub-Cadet-S...YAAOSwg1JcVvOx
Old 03-24-2019, 09:59 PM
rudedawg's Avatar
Thanks Ironman, yeah I saw that one but got stopped in the tracks when I saw the attachment bolts wrung off. That is a given when pulling these mufflers when they have been in use for years.
Old 03-25-2019, 06:50 AM
ironman's Avatar
So if I understand you correctly, you are willing to do whatever it may take to make some other "style/type/brand" of muffler work because you don't want to spend 200 bucks. But you do not want to spend 30 bucks on a perfect fit that simply needs some new mounting studs tack welded on. I'm done.
Old 03-25-2019, 03:06 PM
rudedawg's Avatar
I don't have a welder, would need to find/pay a welder, buy a pop rivet gun & rivets to reassemble the heat shield then maybe would have $75.00- $80.00 in a used muffler that's probably in the same shape as the one I already have. Thanks for responding anyway & have a gr8 day.
Old 03-25-2019, 04:49 PM
You can drill through where the studs have twisted off and tap it for a 1/4" or 5/16" bolt. Easy fix. I've done a couple that way.
Old 03-25-2019, 06:46 PM
rudedawg's Avatar
Thanks Sam Mac, that's a really good idea. When I pull the old muffler out to inspect it for holes or leaking crimp and also replace the exhaust gasket I'll try that. I may even try sealing the threads with some extreme heat JB weld that I have.
Old 05-19-2019, 11:11 PM
rudedawg's Avatar
Good news, sprayed Seafoam Deep Creep on muffler studs, let it sit for 15 - 20 min. and nuts came off without a hitch. Tore the muffler down and discovered frt. & back halves had separated at the crimp on left hand side; recrimped, assembled and installed, now good to go and much quieter.
Thread Tools
Display Modes
