Greg Rozar AKA- CubDieselFan
Old 10-09-2018, 06:27 PM
There is a special c clip holding the bevel pinion shaft thingy, it is behind the welch plug.
Up to 530 and counting...
Old 10-09-2018, 06:52 PM
hyperlightboards48 hyperlightboards48 is offline
Thank you so much! I just went out and popped the plug out but I broke my snap ring pliers earlier today so I’ll need to go get a new pair tonight to spread that clip.
Tanner
Old 10-09-2018, 07:32 PM
A few tips for you
https://www.onlycubcadets.net/forum/...ad.php?t=33244
If you want the Cyclops service manual you can find it on Cub Cadet Cyclops on Face Book https://www.facebook.com/groups/666265203510023/
in the files section. I'm one of the admins so I'll approve you.
Old 10-17-2018, 11:03 PM
Rodster Rodster is offline
Originally Posted by PeterJ View Post
Congrats on the 1864! Don’t blow a head gasket! Advance the throttle to wide open when you shut it off hot or it will backfire!
The pic you posted of the lift arm above the floor board is for the blade.
Your snowblower s/b a 451. A manual can be found online. It attaches under the floor board to lift the blower. The combo unit X-Treme sells is what you need if you don’t have a lift arm for the blower.
You mentioned a jerky hydro. Follow Sam’s advice on changing fluid and filter.
PeterJ
You got that right! Figured out that solution by mistake an no more backfire!
Backfires even when cooled down so must be one of the other issues JMECH mentioned. Some day I'll dig into it but for now opening the throttle work. Father-in-laws 1864 does the exact same thing.
Old 10-30-2018, 09:44 AM
Thanks for the help and the links Sam. I have spent a lot of time on those threads since I picked this one up.
I was able to get everything sealed up bolted back in and started it up instatly started leaking again turns out the right side trunnion seal was leaking as well. Napa has the seal in stock and I was surprisingly able to replace the seal still in the tractor. Not sure what the slot/opening on the right side of the frame is for but it sure was handy to pull the seal 😁
Tractor is sitting the the garage waiting to adjust neutral and put the fenders back on and will be a worker soon.
Here’s a couple pics for entertainment.
File Type: jpg 1870D0F2-FB31-4315-A8CC-CB4E16679D0D.jpg (26.6 KB, 63 views)
File Type: jpg E677977D-27E1-471E-9E80-069A5C0DA1F0.jpg (28.9 KB, 63 views)
File Type: jpg 0DA26632-B14C-486E-A0B0-F2916F359AB7.jpg (21.1 KB, 64 views)
Tanner
