Probably a good time to take off the front axle for some cleaning and inspection also, you think? Taking it slow here...
1951 Farmall H; 1957 Willys CJ5; 1959 Farmall Cub; 1961 Cub Cadet Original; 1963 & 1964 Cub Cadet 100's; 1971 Cub Cadet 106 |
No brainer there
You are already into it that far, why not? |
Well, I got it stood up. Now I have to figure out an easy way to remove that rusted in roll pin!
https://www.onlycubcadets.net/forum/...ad.php?t=58035 |
Meanwhile, the PB Blaster soaking continues...
I am interested in what people have come up with to brace the input shaft on the trans from damage hammering out the pins. I'm going to be doing a clutch replacement on my 73 soon and after reading this I'll be taking preventive steps before hammering on it.
Daniel G. . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
You need a good set of roll pin punches.
Prices are all, over the place on these. I'd stay away from the cheapest. Mine are vintage Craftsman and have never let me down and they get used quite often. Here's one. https://www.napaonline.com/en/p/PTQJ49007S2 |
All is looking good with the clutch. I don't think I broke anything getting the shaft off. I borrowed an idea for compressing the big spring and have replaced the teaser, the compression spring, the shaft (which was pretty badly worn), the bearing and the disc. Got it all together and it's ready to go back on after some work on the frame.
Can do the same thing with a vise, a brass drift and a hammer.
Oh, I'm sure, but I had all those parts laying around and thought I'd give it a try. Worked great. I'll probably use it again if I redo the clutch on my 106, so no harm, no foul. It was fun figuring it all out.
Thread Tools | |
Display Modes | |
