Mechanical PTO for K241, & K301
Good day. Can anyone tell me if the pto clutch pressure springs (triangle ones) are different between the K241 and K301? I am installing a built up K241 into a 128 tractor, the K301 engine was cracked.. I had the K241 already. The PTO clutches on both engines were missing parts. I see some pressure springs are flat on the end, and others have a bend that appears to rest inside the hub.
Thanks |
There were couple different types of mechanical PTOs that evolved over the years and then there was a mechanical PTO with a brake. Check out this link:
https://www.onlycubcadets.net/forum/showthread.php?t=9 Note the type of PTO used corresponding with the model of tractor (actually by serial #) regardless the size of the Kohler K series engines. Edit: Damn, Roland beat me....
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
Thread Tools | |
Display Modes | |
