1200 Front Blade
I recently bought a CC1200 which came with a snow plow. I puzzled quite a bit about how to attach the plow, these manuals you folks posted help a lot!
On a marginally related note, my equipment lift lever has broken its return spring, which means it will no longer lock in place at intermediate settings (the button stays down unless I pull it up). Can this be repaired? I am not even sure how to get into that lever. Thanks again! Uncle Bob |
First, welcome to OCC.........
The installation manual for the Front Blade is here. Click on WF-1 or WF-2.... Manuals You can replace item #7 on your Implement Lift Handle.
Before you replace any parts, you might try spraying some PB Blaster or WD-40 around the button, let it soak in a bit and then work it a couple of times. It may be just rusted up or seized and that could allow it to actuate freely. I've had good luck doing that in the past, so it may be worth a try. If not, replace as Roland suggested.
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. |
Thread Tools | |
Display Modes | |
