Greg Rozar AKA- CubDieselFan
Old 05-04-2021, 07:37 PM
Moneypit Moneypit is offline
It's the same image twice, but I circled where the belt rubs in the second one.
The 44" was too narrow and the gauge wheels hung up on the rear tires once I installed the correct diameter. The 50" runs fine except the belt drags on the sub frame. Neither were original to the tractor, so something needs changed and is not right. The only thing that makes sense to me is the front deck hangers, but I only see one part number listed and I sold the other deck 2 years ago, so I cannot compare, but my memory says the hangers on this deck are shorter.
IH Cub Cadet 982 with 50" mower
Old 05-04-2021, 07:52 PM
Possibly. The front hangers are adjustable.
Roland Bedell
Buy: Made in the USA
Old 05-04-2021, 08:40 PM
Are you "hanging" the deck on the mule drive or is it running on the anti scalp wheels?
it needs to hang on the pins in the back and in the support hangers in the front.
Your pix shows the deck is not hanging on elongated supports, it is pushing on the bottom of the elongated supports
Try adjusting that, also move then as high as the you can and still have your deck properly adjusted a bit lower in the front.
Old 05-04-2021, 10:33 PM
Looks like the wrong mule drive to me. The hangers on the front of the deck should be on the outside hole.
Up to 530 and counting...
Old 05-05-2021, 08:40 AM
ironman's Avatar
ironman ironman is offline
I don't know if any of this will help but these are snip clics from Cub Cadet Form 772-3791. I have it on my hard drive but I can't find it anywhere on the web to download.
Old 05-05-2021, 08:58 AM
I saw that also, my 50C on my 782 is offset so the rear DECK wheels do not contact the rear tires, as he mentioned he had a problem with.
But I'm not familiar with a 982 mule system.
When I put a 50" deck on my 1650, it uses a non offset mule and inner front hanger hole like he pictured.
Snap a pix or two of your front idler mounting on the mule, they should be offset and be the
wider pulleys for the 5/8" wide belt.
Old 05-05-2021, 09:08 AM
I think you are right. It may be that GT Mule Drive was adapted to fit on a 982.
Roland Bedell
Old 05-05-2021, 02:29 PM
It looks like he has the correct hanger, but it should be in the correct hole on the front hanger, also the manual for the deck install shows this hole with the link installed.
Old 05-05-2021, 05:00 PM
Something just don't add up. Most of us know the 44C and 50C decks mount the same. He claims they don't.
Roland Bedell
Old 05-06-2021, 06:51 PM
Radioguy41's Avatar
Radioguy41 Radioguy41 is offline
A photo of the mule drive might help. Here's the page from the manual explaining which holes the mower frame mounts to on the mule drive. Note the 982 uses hole #3 (rear most).
1980 IH CC 782
1957 Cub Lo-Boy
1993 Craftsman LT4000
