Greg Rozar AKA- CubDieselFan
Old 04-09-2021, 11:17 AM
ray77 ray77 is offline
Default XT1 engine problem
I have a 2019 XT1. We can't get it to idle down. It has a Kohler Courage 24HP in it. When we crank it, it almost sounds like it's blowing up. Any suggestions ?
Old 04-09-2021, 12:44 PM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
First things first,,, Welcome to OCC!
As for your machine, I personally have little experience with the new Cubs but based on general engine info, take a good look at your throttle linkage around the carburetor. With the engine off, move the throttle lever up and down on the dash, and watch the linkage at the carb.
It should move freely, though IIRC the throttle on the carb itself should stay wide open because of the governor.
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 04-15-2021, 10:32 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
Check both ends of the throttle cable.
The end under the dash has been know to fail this can cause your problem.
JD x475
Old 04-16-2021, 10:26 AM
Leadslingingdaddy's Avatar
Is this before or after it starts?
