CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Old 05-11-2022, 09:13 PM
Originally Posted by MikeM View Post
thanks Ken All the pulleys move freely are smooth when turned. when you referanced to idler pulley i assume you are talking about the one that is spring loaded, if hinged refers to its abilty to move back and forth that is OK also. The belt on the deck is not the problem its the PTO belt, i am assuming you are asking because it may be related to my problem.
Sorry if i am not understanding all of this, and thanks for your help.
Mike
I have had trouble breaking PTO belts with bound up spindles in the past.
Figured the PTO belt was just working way to hard spinning the deck.
Hope you get it figured out soon.
Ken
Old 05-11-2022, 11:08 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
Take apart the tensioner on the deck. I bet you'll find your problem. The bolt it pivots on is probably badly worn or partly seized. It's the weakest link.
2084 loader
1864
3235
Old 05-11-2022, 11:28 PM
Ozcubowner's Avatar
Ozcubowner Ozcubowner is offline
Get a parts manual and check the deck schematic against your deck and see if anything is different , also the two new pulleys under the PTO are they spinning freely
Here you go
https://www.cubcadet.com/en_US/conte...a24fb15d2bfb/y
Oz
Old 05-12-2022, 08:01 PM
reidcc's Avatar
reidcc reidcc is offline
Thanks again Roland
That is how i have it, the 5.065 receives the PTO belt and the 4.659 drives the blades. Also it takes a lot of effort to tension and lock in place the PTO belt which is back to my original problem.
Mike
Mike-
I have the 2500 series version of yours, which is the 2544(44 inch deck). I can confirm on my deck- the bigger pulley is used on the PTO belt, while the smaller pulley is for the deck belt.
Chris
Old 05-12-2022, 08:17 PM
MikeM MikeM is offline
thanks Chris that is how mine is.
Old 05-12-2022, 08:32 PM
Ozcubowner Thanks for the drawing, everything looks like it matches, also i removed the two pulleys and spun them while holding the bearing they spun freely with no binding replaced on tractor and still free. The belt being so tight going on seems to be the problem but cant find out why. Thanks
Old 05-12-2022, 08:39 PM
reidcc's Avatar
I have also had issues with the PTO belt getting smoked, and there have been a few other cases of that back a few years if you do a search. There never was any rhyme or reason as to WHY these would smoke.
All I could do was to check and make sure I had the spindles lubed, the idler lubed, and ensure I had the PTO belt oriented correctly where it wrapped around the front mule pulleys.
I see the cost of these things had really gone up too. Last time I bought a PTO belt(OEM Cub) I was like $38. I thought I just saw prices of up over $50!!!
Old 05-13-2022, 02:41 PM
Ken41's Avatar
Ken41 Ken41 is offline
I have a 2165 with a 46" 3 blade deck and was going through CC $44 belts. (PTO pulley is larger one on top) I found $15 made in the USA belts on E-Bay and am using them now. Actually I have 3 brand new ones in stock. What I did was clean all the junk from the bottom of the deck, did not seem that bad and sharpened the blades. When there is tall damp grass or thick areas I take a lighter cut and drive slower. In other words I do not over load the deck. Have not broke a belt since.
Copyright ©2000 - 2022, vBulletin Solutions Inc.
