Cub Cadet Classics R. F. Houtz and Sons
Patton Acres Binder Books
CC Speciaalties IH Cub Cadet Parts
Only Cub Cadets Chat!
OCC Archives
Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Kubota Engines
Old 03-11-2019, 05:30 PM
When I first got my 1572 in 1998. It would run great at half throttle and no load. It would stall and quit sorta like you are explaining. I changed the filters and it was all good.
1572, 1864, 1810, 1863, 1811,782D, 1872, 782DT
Old Today, 03:16 PM
jpswift1 jpswift1 is online now
I changed the filters and put fresh diesel in it and it didn't do anything. I took the lines off at the injectors and it is getting fuel.
Is there any way to clean the injectors and test the pressure at the injector pump to make sure it's working as it should?
Old Today, 08:31 PM
You should just loosen the line a 1/4-1/2 turn @ the injectors one @ a time and crank it.
It should squirt fuel from the loosened fitting and that bleeds air out of it.
To answer your question:
Yes, a diesel shop can test and adjust the cracking pressure of the injectors.
I have done a few. it is not something you can do yourself effectively.
What you can do, is remove the injector and hook it to the line and crank it to see if it will spray a cone pattern.
( different engines have different patterns)
Just be careful as they are in the vicinity of #2000 give/take.
It will pierce your skin if it is exposed to the nozzle spray/pressure.
Be sure to have the throttle open when bleeding/testing
Old Today, 08:36 PM
The secondary filter may have air in it, unscrew the plastic filter housing a little and turn on the key to push out any air in it. It will make a mess....
we have a few here...
Old Today, 09:20 PM
Thank you for the help! I'll try that tomorrow and see if I get somewhere.
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
This website and forum are not affiliated with or sponsored by MTD Products Inc, which owns the CUB CADET trademarks. It is not an official MTD Products Inc, website, and MTD Products Inc, is not responsible for any of its content. The official MTD Products Inc, website can be found at: http://www.mtdproducts.com. The information and opinions expressed on this website are the responsibility of the website's owner and/or it's members, & do not represent the opinions of MTD Products Inc. IH®, INTERNATIONAL HARVESTER® are registered trademark of CNH America LLC
